Hey guys
Just thought I would throw this up here for personal opinion
I'm just tossing up idea's on whats going on.
The problem that I am getting is that the engine doesn't like timing.
Its running 17 deg advance at 7500rpm. anything more and it wants to ping
Ran BP ultimate on the day. Bad batch of fuel would ping like crap coming onto load.
The problem that I am getting is that it wants to ping top end.
My setup is this:
r33gtst manual
155-160 +-5 across all 6 when warm
580cc high flowed sr na injectors (tested, spray pattern perfect all, all spraying same amount when tested)
Plazmaman Plenum
3" stainless intercooler piping
600X300X100mm intercooler, kls power spirit
bosch 040 in tank pump
splitifre coil packs
standard fuel rail and fuel pressure regulator
3.5 inch turbo back stainless mandrell bent exhaust.
3.5inch cat, 100 cell brand new
6 boost manifold,
Tial 44mm External gate
GT3076R
.60A/R anti surge front, .56 Wheel trim
.82 rear, .84 wheel trim
external gate 4 bolt rear, 5007 3076R
Testing done so far:
Pressure drop of intercooler. .5 of a psi drop from turbo side to inlet plenum
Exhaust pressure is only at 3 psi at ful noise
De-carbonise tops of pistons/cylinder head clean (did f**k all)
Ive got this thing tuned with the aid of Exhaust Gas Temperature senders on each cylinder, they are all on par and off the top of my head should be somewhere around 650 degrees (don't quote me)
Ive got two things that i want to address.
does that dyno sheet look to be about right?
and apart from the heat on the day (35 degree's in the dyno room) would there be any other reason to blame something else apart from heat soak for this problem
Discuss.
Edited by sriver killer
https://www.sau.com.au/forums/topic/352597-critique-my-dyno-graph-gt3076r/
One thing to try, get a long piece of pipe, put it between the pod and the turbo and see if you have the problem when you are ingesting room temp air rather than post radiator air.
bit too late as it is off the dyno, i honestly didn;t think it was goign to make that much of a difference,
seeing as cold air intakes only give at best 5kw atw gain.
Just saw you have high flowed injectrors......eeek. Did you work out which cyclinder is pinging? Then I would swap injectors and see if it follows. I have not had a good set of high flowed injectors yet. Can you borrow a set of nismo's?
Also the pod in the engine bay is sucking a lot of hot air prob over 45degrees that day...would kill power. What was the intake manifold temp?
The fact its doing it up top is whats making me think its the charge temps. Be it timing or the CAS I would expect it to be more likely to occur when coming onto power, or if it were electrical and up top I would expect it to be erratic.
This seems more consistent with poor charge temp due to the position of the pod. Dont forget as revs rise under bonnet temps soar as the manifold gets hot and emits heat, and the clutch fan pulls more hot air through the rad which has only one place to go, the big vacuum right besides it.
I'm thinking along the same lines.
Have a look at this dyno sheet of my vehicle, doing consecutive power runs
under bonnet temps would have rose something chronic
would it be enough to still cause that much power loss, we are looking at 70whp there, that is a bit much isn't it?
even at 380whp i thought that this setup would produce more than that ( done when intake temps are low)
Ive got one of those KLS power spirit intercoolers,
They Flow alot, and have quite large fins,
previously i had a really dense intercooler.
got me thinking that in 36 degree's and with my pod sucking in All that hot air the thing wouldn;t really be cooling it in a dyno that has 36 degrees ambient temp
It has been tuned for 11:1 AFR's so some of the power can be found by pulling out some fuel and taking it toward 12:1 or wherever it makes best safe pwoer.
The richest run (10.8) to the leanest run (11.2) on that dyno makes about 45hp difference at 5600 rpm.
The KLS cooler looks like a run of the mill china job. Decent enough for what your doing but hardly the bees knees.
Honestly, chuck it back on the dyno with your pod hanging out of the bonnet rather than under it. Instant answer for that one, yet guaranteed the intake temp on that would be 60 degrees on its own BEFORE its compressed IMO.
checked your fuel filter lately? mine was blocked and was causing mine 2 lean out on dyno aswell. replaced pump first cause it was a bit noisey, but later decided to pull fuel filter off and i couldnt even blow thru it. problem fixed after that. also try a different CAS. mates 32 was making 450rwhp then next run 350 then 370 etc, replaced with a dif CAS and problem solved.
17 degree of timing is a good amount on full load. Perhaps use a timing gun and see what base timing you're running.
On my old car, I found out the base timing was set at 21 degrees, don't ask me why.. so I dragged it back to 15. Even on full load, with a tiny ass turbo @ 1.3bar, I only could dial in 12 degrees on full load, and 14 around red line.
I would personally lean it out a tad, seems quite rich and back 1~2 degrees of timing on load (usually rows 16/17/18)
Pretty sure my car only ran about 17 degrees of timing at 7500rpm. That side of things sounds normal.
376hp @ ~18psi sounds perfectly normal to me for a 3076R.... I'm not sure what your expecting/complaining about.
Thats what I was thinking too, glad I asked... I thought I might have been going mad or something.
I suspect there is no problem, the car is making what you'd expect on that boost, with that fuel, with that turbo :)
my 2L made 374hpatw with 21psi with 17˚ timing at 6800 on bp98. i'd say the figure is about right.
Hey guys
My setup is this:
r33gtst manual
Plazmaman Plenum
6 boost manifold,
GT3076R
Discuss.
That is an interesting boost line you have there mate...
Where are the rpms on the graph?
And I've never seen a dyno graph with kmp/h on the bottom before lol
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
