This may not be to do with "what fuel is the best to use" etc, but it's quite amusing how people complain about the price of petrol, when 1litre of coca-cola is still more expensive than 1litre of fuel!
  • Replies 45
BP Ultimate 98!
I also filled up with Vortex on a stock r34 - definitely noticable. I would argue that you may not notice it if you drive your car ><30% throttle then yes it might be all the same. But I tell you once boost comes on and you wonder -- hmmmm I remember there being a bit more response & torque..
I once had to fill 95octane, I swear one day in the CBD - approx nov 2010 3 different servos had 98 out of service - I tell you this is the time I started believeing in the dodgy wednesday outof service policies where some servos take 98 out of service. Under no circumstance would I ever use 95 but I was so low I had no choice.
And hence 95 octane made the car feel like a 2ton hiace van.
Fact - The base fuel that the majority of fuel companies in WA use is from the BP refinery. I say most because some cheaper brands like Gull, Peak, United et al, import some of their base from Singapore as they may get it cheaper. Hence, why you never know what type of fuel is in them
Fact - All the majors spend millions of dollars on chemist, physicists to come up with mixtures that give them an edge over their competitors, so even thought the base is the same the end product is totally different.
Fact - BP Ultimate 98 is the only 98 RON fuel that is made as a 98 fuel from the start in WA. Shell do not supply their Optimax anymore anywhere in the world, they supply V-Power over east because they have refineries in Geelong (Vic) and Clyde (NSW) and ship/truck it to QLD, SA. Transport costs prohibit the supply in WA and they do not want to give BP their ingredients for them to make it at Kwinana, competitive forces at work. All the other 98 fuels in WA are made from additives, so to speak.
Fact - Not all fuels are the same, and anyone who thinks so is kidding themselves. A perfect example of this is Ethanol fuel, even with the same Octane rating you get less energy from it then an equivalent RON non ethanol fuel. Sometime you can get more power from 95 RON than 98 RON fuel if the density of the 95 RON is greater, but only if your car doesn't need the heat protection of higher RON, e.g. turbo cars.
Fact - They all have to comply with governemnt regulated maximums in sulphur, benzyne and minimums in RON but there are a lot m ore other factors that are not regulated and the different fuel companies use this for the competitive edge.
How do I know all this, I work for one of our fuel majors and have lived both here and in Vic. I can honestly say that the best fuel in WA is BP Ultimate 98, but overall the best is Shell V-Power, as I used it when I was in Vic.
So, go on and use the cheapest fuel or the most conveniant location on your pride and joy and you certainly will not be getting the most out of it and possibly damaging it.
I don't notice any difference between Caltex 98 or BP 98 on my car.
Currently using BP atm, since I got a $100 BP gift card from my parents but otherwise I mainly use Caltex since its cheaper.
only problem with this is its never regulated after being at the servo and its very hard to tell when they're getting low. i've had bad batches from low servos a few times and there is no way in ther world it was still 98RON.
at the end of the day, its unlikely your gonna notice any difference between different brand of 98 on a stock car. if your cars been tuned, use whatever fuel it was tuned with. if its about to be tuned and you can afford their ridiculous prices, BP ultimate is usually the best.
JonnoHR31, the best regulator is the customer...if you suspect someone was ripping you off you can report it to the Consumer Protection agency. It is their reason for existence to help you out and investigate this. It is often the case that the most powerfull people, the customer, don't do anything 'cause of the attitude of being just one person and that is why some business's et away with ripping people off!
Yeah straight out I've been reading all the posts and to be honest I think sometimes Caltex Vortex 98 could even be better than BP Ultimate - but this could be due to fuel density or some other variable that has nothing to do with octane rating.
Caltex Vortex 98 is always cheaper as well but I am a born and bread BP fan especially after reading the big post a couple up haha :thumbsup:
yer i know but by the time they get around to testing it they would have probably filled up as its usually only the nearly empty servo tanks that give you trouble.
u.k is tiny, they barely travel any distance by car, hence why higher fuel prices arent as bigger deal as here and the US
    • If there's a next time, next exit after mine is Costco 😛
    • OK. But what about parts of the block that, when assembled, were twisted into a position that pushed into the void space, which, when disassembled, then released that force and opened back up, thus putting the grout into tension? Would effectively just pull the cast iron off the grout at the interface, leaving a tiny void and benefitting not much at all. Swings, and roundabouts. It's like putting something tiny into the fleshlight and finding out you needed a smaller one, to perhaps follow your area of expertise.
    • Nah. You buy a kit that has shorter tubes.
    • I didnt present too many conclusions because I wanted your opinions and feedback based on your own experiences. I don't know the exact material, but it is similar to concrete and therfor only has valuable strength in compression. The forces on the set material once the head is removed would mostly be in compression since the grout wants to retain its shape and the block wants to return to its relaxed state since it's still within the elastic region. The grout would theoretically make the block more rigid. The exact amount would take a better setup on my end. Thought experiment: Instead of aliens, twist your favorite fleshlite. Now fill it with grout and allow it to sit for a week. Now try to twist it again. Observe what you see. Now get your other one and blow into it. Observe what you see. Now put it into a can and fill the space between your fleshlite and the can. After it sets blow into it. Less movement in torsion and less expansion i hope.
