This topic has been covered many times before.
My opinion - go for a high flow panel filter like a K&N. Though you'll only be looking at minimal power gains. To maximise bang for buck, you could run another pipe from the front bumper up to the airbox for extra cold air (together with the stock airbox intake funnel).
I think pod filters are a waste of time with or without a heat shield.
Cheers
I used the search button and found this thread! I also am thinking of removing air pods and goin for stock airbox. But dunno if my GReddy intake piping will line up with a stock air box.
Maybe a custom made one is the go! ? Can't imagine all that hot air is doin the intercooler any favors....
I agree,
I think after reading many threads & different methods the best set up is a dry panel filter with a custom cold air intake
system at the front bar...
This thread was purely intended to get as many people's outlooks on Pods Vs Panel set ups, so please throw in your 2c.
  • 3 weeks later...
If you go pod you have to build a heat shield, otherwise it will only sap power and promote detonation. They do make it sound better apparently though. The verdict, thread after thread, tends to be go with a decent panel filter, and cold air intake if you're hardcore :D
  • 1 month later...
  • 1 month later...
When i bought my 33 gtst it came with an uncovered pod. I was made aware of them soaking up heat so i made a shitty shield in an attempt to stop it, but dont think it helped much. I have never really cared either way, but after going in my other mates gtst with standard air box, the pod does give my car a much cooler induction sound. I honestly dont think there is too much in it if both are set up well, but there is a sound difference.
Thread closed. Believe it or not, but since SAU started more than 7 years ago, this topic has been discussed before.
Please use the search function in future. It may be found here:
http://www.skylinesaustralia.com/forums/search.html
While we understand that it can be frustrating to have your thread closed - Please consider that other members may feel it to be disrespectful and selfish of you to post a simple question, without using the search feature to review the wealth of information provided by said members over the years.
If you still feel that this action is unjust, then please PM r31nismoid or pal and we can discuss it further.
Edited by Thelen
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
