i just purchased my first r32 gtr. when i picked it up friday the car, when i started it seem to have a miss, but i couldnt tell. it runs like it have a bigger cam. sounds very lumpy. it only does it at idle. does anyone know if there is problem??? when you increase power, typical gtr exhaust note but when cruisin it sounds like it isnt running on all 6 cylinders. i have checked the spark plugs, coils, injectors. i think there my be some sort of air leak. i sprayed some aerostart near the no2 and no3 injector and the car ran perfect for a second the miss was gone and then came back again. also i looked under the rear of the car and the diff has the typical v spec oil cooler fins on the backing plate. does this mean its a vspec??? how else can i tell? can someone help? the car has done 90klm. also with the gtr are they still speed limited to 190km? thats where mine stopped.
https://www.sau.com.au/forums/topic/35272-r32-gtr-v-spec/
As far as i know all standard R32 GTR's have a finned diff all V-spec and V-spec II have a flat diff cover so the opposite of the R33's. Best way to tell is the model code V-spec II have KBNR32BFS8 AA where a V-spec does not have the 8 on the end and normal GTR's do not have the S or the 8 on the end.
https://www.sau.com.au/forums/topic/35272-r32-gtr-v-spec/#findComment-711652
The miss is no2 inlet gasket has blown which requires removal of the plenum/throttle bodies and inlet manifold.
There are three sets of gasket there and best to replace them all.
Have fun, it's a bitch of a job...
V Spec usually means that it has 330mm rotors and brembo calipers.
Finned diff means nothing...
Cheers
Ken
https://www.sau.com.au/forums/topic/35272-r32-gtr-v-spec/#findComment-732257
