I know it's a long shot, but does anyone have one Kumho KU36 225/50R16 tire they would like to sell me?
Flat spotted one at Winton a while ago and I'm going to Haunted Hills next weekend. If I don't get a replacement I'll be running on mismatched wheels :(
Thanks,
Josh
https://www.sau.com.au/forums/topic/352726-22550r16-ku36/
  • 1 month later...
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
