I've got a pretty droney exhaust fitted but i want to quieten it down a fair bit. i'm not looking to make it completely silent but at least tolerable for daily driving. i've done a bit of searching and so far i've seen a lot of people say resonators are crap and only some mid-mufflers work.
does anyone have any first hand experience with mid-mufflers that work? or have any other useful options?
https://www.sau.com.au/forums/topic/352752-quieten-down-a-performance-exhaust/
How big is the exhaust?
My 3" is NSW rego legal and i dont have a large middle muffler its just a hotdog and a 16x11x6" rear muffler, if its 3.5" on a 33 a 16x12x8" muffler is about as large as you can physically fit on the rear 18" long at a squeeze. if you really want to just add a middle muffler i took some measurements and you can fit a 17x8x5" muffler (offset/centre for the inlet/outlets)
The people that are saying you have to get a decent mid muffler are the ones that want to have a cannon muffler sticking out of the bumper.
i THINK its a hks hi-power exhaust. looks like a 5" tip with a 4" inlet. its a 3.5" most of the way then ends with a 3" where it meets the cat. quite weird but thats what i've got. i think i'll go with a mid muffler and if that doesnt work i'll add another.
The stagea has a mid muffler but Ms Wolv wanted it dead quiet so we fitted a custom 3" straight through 18" x 12" x 10" (lots of height and room back there) and it is quieter than stock.
In a bid to discourage more "random breath tests" by our increasingly pro-active constabulary I also modified the R33. It had a 3" exhaust with hotdog and largish cannon. I replaced the hotdog with a mid muffler (prob 12" x 10" x 6") and it dropped the noise significantly, later I changed to an oval rear muffler (12" x 10" x 8") and it is quieter again but not stagea quiet. Located in the Hills if you want to see want to see and hear.
have you got any further info on where and what brand the muffler is?
Stuart @ Racers Choice in Seven Hills sorted both cars out for me.
I have no doubt there are some off the shelf items that might suit but the rear muffler for the stagea needed custom building. This was manufactured elsewhere but I am not sure who Stuart uses.
I agree with Nismoid and Wolverine. To get the best/quietest result you'd need custom cans that fill the available space.
I'm running 3.5" right through, two Hurricanes as big as would fit. No drone, but it is a touch too many dB. Depending how things go over time I may have a custom can made too.
Be aware that the number of bends and pipe diameter does have a big bearing on how much noise reduction is required.
Im a fan of the Magnaflow mid-muffler Resonator, ie 'hotdog'
go for a 5" body with 3.5" in/out centre to centre. ebay USA is best place to find a good price for these.
im using a 4" body with 3" in/out c/c to a kakimoto gtr racing end muffler 3" in/out centre/centre
Noise isnt that loud, a little drone at 1600-1800rpm on 5% throttle, whilst on full throttle the most noise is from the intake/turbo not the exhaust
  • 8 months later...
Sorry to dig up an old thread but I've got a related question.
Currently running a straight through exhaust on my gtr, will the car need a retune if I put my big rear muffler back on? It's quite a large muffler with a 3 inch inlet and I think a 5 inch outlet. Looking to quieten it down a little for a week or so while I daily it.
Cheers.
+2 to Nismoid and Wolverine to fit custom straight through mufflers as large as you can fit.
I also had an 18" x 12" x 8" muffler fitted to the rear of my 34 (3.5" in and out). Its bloody massive but fitted and tucked up in there nicely. Car is super quiet but still sounds good and made good power.
If any of you guys have heard of this Jap exhaust brand called St. Mays they're the most quietest exhaust I have EVER come across on any RB. I ran one on my 180SX with a RB and it was so quiet I had to chop off the rear cannon and replace it with a HKS Super Dragger for some noise, even now (my friend owns the car) when I drive the car, it would probably idle as quite as a stock Skyline and when on boost would make less noise than a V8
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
