Zoid's Gts Build
zoidbergmerc
 Share
  • 4 weeks later...
That dash wouldn't be hard to replicate poit. I personally wouldn't give up my factory dash for that, but that's me. To make that in 1-1.6 mm ally sheet would be fairly easy, weekend job tops. Looks to be just satin black, few hole saw bits to match ur gauge sizes etc. looks NASCAR spec
Edited by Mr. Untouchable
yeah I think I should just tidy up my stock dash and leave it, take the heater core and AC out too, seeing as they're not hooked up...
I need to make some door cards more than anything!
Edited by zoidbergmerc
  • 3 weeks later...
I've been fooling around with the 33 and took some pics to share.
So I thought I had a pretty major problem when at symmons plains I was getting some SERIOUSLY bad vibe through the wheel\car when going faster than 90kph. I was like the f**k my car is going to fall apart.
I was pretty convinced that something was seriously a miss with the passenger side front suspension\bearings, something was not right. I pulled it all down and low to behold, it was all brand new, it wasn't till I was putting the wheel back on that I discovered the massive flat spot on the tyre -_- FAIL
Then I painted and fitted my new wheels, they're Rays SS7 18x9.5 +38 but to get them to fit I had to install a 15mm bolt on spacer as they fouled on the upper wishbone(?) when on full lock now it clears by about 1mm. They were gold but now they're Matte black, and I'm thinking of painting the lip red to match my lensos and break it up a little. The tyres are Dunlop D03Gs in a medium Compound, 245\40\18 for the front and 265\35\18 on the back.
I'm pretty sad about my Drift Teks getting so f**ked up after my little spill at Symmons :( Those rocks hurt!!
I also put in a passenger seat for the Charity Rides day in a few weeks :)
I also fitted some new brake pads, Hawk DTC-60 should pull the while whale up nicely :)
I like those new wheels, I reckon they look good as they are but to match the Lenso's would look better with the red lip.
What brake pads were you using?
Hey Pete if you didn't already know its really easy to add a stripe to the wheels. You can either buy some red pin stripe or cut a pice out of vynal. It can just be a strait pice. As you put it on the wheel it will flex as such and turn a strait line into a curved line. So no need to paint it or cut out round stripes. I have done this neumerous times to wheels on a race car I used to look after.
 Share
    • So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.  I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan. So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea. The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit. So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent. The price difference between the 300 and 400hp models seems a bit crazy. Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k From my limited research it seems that the only differences are that the 400r/Red Red runs more boost and a more aggressive tune. There are are turbine speed sensors on the turbos. Has 2 pumps for the water to air intercooler. Runs an engine oil cooler. I'm guessing that the exterior trims might look a little more sporty as well. I had a lazy look for upgrades to bridge the gap on z1motorsports They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD. Personally I would rather get the car tuned on a dyno which would probably add more cost Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750 So the total cost could be around $5100 So for easy number 5k + 27K = 32k I guess that would leave some change left over to swap out the open diff and fit a LSD Any thoughts?
    • Right, not sure why I thought it to be a lean spike. It might be fixable with modern card-style hot film MAFs which have some design features to avoid counting reversion flow but I've never tried it myself.
    • I did not realise this, I'll contribute more and earn my stripes and retry later.
    • I'm only going to hassle you for posting links to images. It's against my policy to click links that could be some nasty payload. Sadly, you need to make 9 more posts before you can just stick the images directly in a post, unless @PranK sees this and bends the rule for you.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
