I rolled mine with a 70mm pipe then gentley smahsed the f**k out of them with my 4pound snap destroyer cold blow hammer.
beeeeeeeyaaarrtiiifoool
FINE PRINT - YES it took me around 3 hours to then reapir each of them and shape them pissing around with my slapper hammer and various dolley's and contour guages, and then almost a full respray hahaha
well mine are a lot worse than Jacks, I'm a little disapointed, I couldn't see the damage that was being done until I stood up and the light hit it, looks like a retard has assaulted it with a bb gun -__- oh well, they're only guards on a drift car :P
you can't tell in the pics though! hehe. Pulled the fronts out about 20mm. I might have to spend the next 3 hours reapiring each of them and shape them pissing around with my slapper hammer and various dolley's and contour guages, and then almost a full respray
Edited by zoidbergmerc
looking at that lip though...they still dont fit? :blink:
i mean, youve fuarked the guards already, so might as well make them so they definitely wont shred your valuable slicks?
It's just the angle of the photo, it should be OK. Going to nubco now to get a bigger pole to pull it a little more just to be super sure. Looking at some old gopro footage, looks like the front wheels travel about 70mm so I'm trying to accommodate for that.
I'm going to raise the nose up another 10mm too, looking at the car side on, looks like it's under brakes already :P
Interesting tid bit.
I had my car on the turnplates and beaurepairs the other day and it got 41 degrees of steering angle (not sure what stock is, quick google suggests it's 36 degrees). Only mod is these http://www.gktech.co...uctID=NISS-TROD
They're good gear, I'd reccomend them to anyone with a skyline even if you're not drifting, just makes moving around so much easier, I can do u turns in the street and drive straight into my garage because of them :)
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
