White whale ready for tomorrow :D changed diff oil now, it was very shiny and had a couple of bits in it so hopefully it'll be better with fresh oil and stop peg legging!
Autobarn were the only people who had Motul FF LSD oil and it was hidden behind some other oil too.
Nope, still peg legging :( heaps.
Only got a 67 :( Which was rather embarrassing seeing as I got a 66 in Dan's 33 :P
New tyres are really good though, getting some good entry speeds, rear is pretty wild though. Maybe need a big wing to settle it down?
Or softer setting on the rear sway bar? softening the rear dampers helps too yes?
Just going off what I read on here
http://www.mcasuspension.com/setup.pdf
So, I've got the Nismo GT Pro LSD 2 way diff.
For future reference and if any one else needs to know about rebuilding a Nismo 2 way here are the two PDFs you'll need
http://www.nismo.co.jp/products/competition/lsd/pdf/lsdpro_price.pdf
http://www.nismo.co.jp/products/competition/lsd/pdf/repair04.pdf
Just putting them here for later :) of if anyone else needs to rebuild a Nismo two way diff.
it should be if it's a gt pro
http://www.nismo.co.jp/en/products/competition/lsd/gt_lsdpro.html
if you pop the shafts out, there will be a 19mm hex head under one of them. You have the option of 3 settings soft med and hard
I didn't install it so I've got nfi, I'll pop the shafts off this weekend and scout it out.
I'm thinking rebuild might be required though because when I dropped the oil out lots of bits came out, looks like some one's put a fist full of 5c pieces in a blender.
New fiber glass guards should contain my wheels nicely.
Edit:
And here is a pic of all the bit o diff that came out. Prolly heaps more in there.
Edited by zoidbergmerc
  • 4 weeks later...
New Cazman adjustable Camber, Traction and Toe arms.
Installed.
Installing them was easier than sitting down, one hint though, to remove the Traction arm, you need to have the camber arm out of the way. I only noticed this after I'd installed the camber arm and had it all torqued up.
  • 4 weeks later...
Got my Diff rebuilt, biiiiig shout out to Martin at Tas Mobile Mech for getting it done for me! Also to Dave.TAS for helping source the parts!
Here is the old vs new shot
hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm, not good!
Fresh Diff felt amazing though and I managed to rip some pretty good skids on Saturday at the Time attack.
I think the 3rd one is my Fav :D Might have to get a print and hang it up at work to remind me why I go there every day.
Results from the day were, 6th in Drift and 2nd in Time attack (Race Class)
Casualties were, another radiator hose and the loom that goes up in the front guard so now non of my accessories work :( Managed to test the endurance of my car though, lasted a whole Time attack session, like 30 mins easy, water temp didn't get above 90 :) I was doing like 2 hot laps and 4 cool down laps then two hot laps, ect ect.
It was a really special day, I just wish more skylines were there to share the experience :) Next time though! all you assholes have to come play too!
your front bar nearly lasted the whole day to :whistling: jokes aside you and the car did really well :thumbsup:
Hahah yeah that front bar Copped it hard!
Cheers man :)
Here is a pic of me not going sideways, a rare sight I know.
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
