Neo's are decent, but it would be an added pain in the ass, Your plazmaman wont bolt up nor will your injectors, they run less duration and more lift plus dual stage vct, so it will most likely cock up your tune. That said better piston/ring land and combustion chamber design with lower comp and of course solid lifters makes them pretty reliable especially if you ran it on R33 electrics and on an R33 76deg thermostat but still you're paying a fair amount for an unopened second hand motor generally with unknown history. I'd go a stocker cheapo 33 or a basic built motor (hint, hint) for sure.
It's going to need a retune regardless if he put the same engine in. The engine is dead from detonation = tune needs adjusting. Engine swaps and tunes are like new girlfriends just because your pecker is the same doesn't mean she will take it the same way.
The inlet stud pattern is the same. So the r33 inlet plus plazman and injectors will swap strait over. Can't see any negatives. Not to sure they are lower compression either. Higher if anything.
Looks like we could do a group buy on engines at the moment. Mine is not so healthy after today. :(
Edited by DJRIFT
Yeah neo is 9.5:1 and s2 rb25det is 9:1.
That's sad about your motor damo :( why'd you do it for?
And yes. If i got a new motor I'd have the tune looked at. While all the engines are equal, some are more equal than the others.
Plus it was the fuel filter clogging up that cooked it, not the tune.
Just stick a 33 25 in it nowelly. Just get one that has healthy comp and obviously one that has as much stock stuff still attached as possible that doesn't look like its been just put back on. Put your sump on it and cam covers and with the money you save buy a accusump setup if you want a extra fail safe. Keep it at 7500 and love life. And from what I can see, and from what you have told me, that motor build/tune is shithouse. Woeful. Oil problems from day dot, then that. Compared to say rusty's car, which he took in, had the motor pulled, built, put back in and tuned to similar power as yours and has been drifted and daily driven for years now and the bill was about 7k or something and has yet to put a spanner to it. Edit, just saw the fuel filter thing, still, undiscovered Amazonian tribes knew you'd have oil dramas with no restrictors and a good sump etc.
Edited by Mr. Untouchable
My bad, for some reason I just thought they had less comp, my R33 RB25's have always registered ~ 160psi accoss the board with my forged 8.5:1 being flat 150, then my R34 neo wavered at ~ 145-150 so it must have just been quite tired :P.
http://www.importworkshop.com/files/manuals/nissan/R33_engine_man.pdf
http://www.importworkshop.com/files/manuals/nissan/R34_service_man.pdf
Google does say 9.5, the manuals don't state the comp though, and interesting (or lazy of them) their compression test, limit and variation are the same on the neo and normal rb25 :/.
Yeah I found out the problem with the tune, there was some stray wires behind the dash shorting out making it forget things! That was really annoying and had me paranoid the whole time.
Stock R33 RB25DET is on the cars.
Unless someone has a head, pistons, rings and bearings for sale?
Or maybe just a head, I've got a couple of 30 blocks lying around here.... (strokes beard)
That's one of the plans Rusty, just get a stock\mild RB25 and throw my turbo\supporting bits on it, just get back out there and start skidding again before the car\project gets stagnant.
Hey Zoid, I bought a full RB25 motor inc loom, ecu, ancillaries etc. for around $1700 to my door 12 months ago from these guys on the mainland Fuji Auto Centre, perfect condition engine, has been running flawlessly for prob 15,000ks now. The guy to speak to is steve, they get crates from Japan quite often and are awesome to deal with, most of their stock will be on here http://stores.ebay.com.au/fuji-autocentre but give them a bell on 0397615203 to see what they have.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
