Thanks for your input guys, it's all really helpful :)
It was funny when I was at the track on Sunday the whole side of the car was covered on oil and some wiser said "Leaking a bit oil oil there hey?" to which I replied, "It's not leaking oil, it's sweating horsepower"
Well, lots of people in the know are suggesting better restricters so I might have to go for that! Then just get some GTR Cam covers and mines baffles when I can find them, bloody things are rarer than hens teeth! Except for those $400 ones on eBay.... he's dreaming.
Here's a diagram of the mines baffles I found, for those who are interested.
Edited by zoidbergmerc
woolly the oils to scared when your making 500rwkw to leave home...either that or the catch tanks filled with alpackers
his catch can was full of grog last time i saw him drain it lol. all it was missing was a slice of lime and some ice cubes.
The size of my wheels in these pictures scares me a little bit...
Awesome day, wish I hadn't tightened my rear sway bar the day before, had no rear end traction at all! That's what you get for assuming it will stop raining I guess :P
Your offset looks pretty bas ass though.
I assumed it was standardish until I saw Alex's car, not many skylines getting around with standard offset/rims.
I need a set of 20's and some spinners to complete the bogan look I'm starting to get. God damn hair grows into a mullet every second week... Perhaps it's fate and I shouldn't fight it?
P.S. This thread is so about me, my hair and my car from now on. Better get used to it :P
f**k you and your hair and your car and your favourite colour!
This thread is now a rageathon about oil coming out of breathers.
Just ordered my mines baffles and oil restricters! Testing the baffles this weekend to see what that fixes. I'm going to go and agree with Jangles though and mines baffles plus 26 cam covers will only increase my engine's ability to store oil in the head. 26 covers with baffles are just treating a symptom, not the cause. But they will help with keeping oil in there when giving it the beans up the hill.
Restricters will keep the oil out of the head and keep it in the bottom end hopefully curing my oil surge issues.
No one seems to know what oil restricters went in there, confused.gif Oh well, you get that on the big jobs.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
