I came off worse for wear this time then I did when you put me into the wall at treefity @ gepps cross paul :D Im achn so bad.
Wine tour wine tour. Followed by powerchuck contest!
Fairy.
How abouts wine tour, culminating with a drunk driving contest back at the go-kart track!!!
