my r33 gtr seats is up for sale. These fit into your existing rails(r33 or r32) without any mods. They are in good nick.. no rips or tears. Preference will given to people who are willing to swap their stock seats. Pics attached..
Price without your stock seats: 850$
Price with stock seats: 750$
Contact: 04211 45480 or pm here
https://www.sau.com.au/forums/topic/352860-r33-gtr-seats/
Hey mate, willing to split the seats up? Am interested in only the Drivers side.
Im in Perth too so unsure how much freight would be?
Cheers, Matt
sorry mate.. i m looking to sell this both as a package.. cheers
https://www.sau.com.au/forums/topic/352860-r33-gtr-seats/#findComment-5665369
dam thats cheap for r33 gtr seats if i didnt just buy recaros i would have got them gl with sale
these are cheap and it is hard to find them that are in good nick.. it took me almost 5 months to find these..
https://www.sau.com.au/forums/topic/352860-r33-gtr-seats/#findComment-5670482
i got r33 series 1 seats would they fit is there any difference
yup these will fit with no mods.. i had series 1 seats when i bought the car. later i 'upgraded' to r33 series 2 seats... then i put on a r32 gtr driver seat. sold them all to get these! so the point is, one size, fits all ;-)
Edited by myskyride
https://www.sau.com.au/forums/topic/352860-r33-gtr-seats/#findComment-5679315
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 馃槀
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
