Hello All,
I'm a noob to the forum. Just wondered if I could get some URGENT assistance.
My R32 GTR has stalled and the engine will not start.
I have checked the following:
- all the fuses are ok
- fuel pump is working
- fuel filter is not blocked
- battery is fine
- starter motor is fine
- fuel tank has fuel
- immobiliser is working
- 12V are going into the spark plugs
I suspect it is the ignitor sitting on top of the engine has died. Today was a hot day.......
Does anyone in Brisbane have a spare ignitor I could borrow (desperately) and see if the car starts. I need to get the car off the street and into my garage.
I am more than happy to come and pick a spare one up.
sms or call 0438 673 426 if you are able to assist.
Cheers
K-Si
https://www.sau.com.au/forums/topic/352861-borrow-an-ignitor-for-r32-gtr/
Hello All,
- battery is fine
Cheers
K-Si
I have a couple of new Superspark ones here. Can't borrow but happy to sell one of them if you need one. I can't really lend out a brand new item to a guy with two forum posts if you understand sorry.
Hey guys,
Thanks for your replies.
I have temporarily fixed the problem by purchasing a 2nd hand ignitor from All Japs Virginia.
The car started straight away.
Just a quick one, has anyone changed their ignitor to an aftermarket one?
I have read that the HKS twin power are reliable.
Is this a common problem with skylines?
If it is heat related, has anyone relocated the ignitor to somewhere else other than the engine bay?
Cheers
K-Si
PM sent
Cheers
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
