ah ok i have pics of the RB30 which im told is the same as the RB25/26 but sorry cant confirm if the same as the ID2000, i don't see what would be so different though
  • Replies 163
Posted Images
here is an install guide from Simon Michealmore
>>Install into Neo<<
the injectors he used were full length ones the ones being supplied in the group buy a 3/4 length
So full length injectors require the 20mm spacers but they Neo injectors in the group buy don't?
I'll be in for a set of 60lb'ers for a Neo as soon as someone buys my 6boost manifold!
yes but its only the Bosch injectors that are 3/4 length but Simon in that thread has just bought the 80lb/h Siemens so spacing the fuel rail must be easy enough
Hey was just after a group buy like this, Well im looking at the EV14 1000cc Injectors for my R34 GTT a set of 6, Will these fit it up properly without height adapters or do i need them, Please let me know what wiring harness also i need to connect it up, i have a R34 GTT RB25DET NEO
I even want the Walbro GSS342 fuel pump, Can u let me know how much my total would be.. Cheers!!
hi Zaver the EV14 are a 3/4 length injector so you don't need height adapters
1x EV14 1000cc $580
1x set harness $66
1x shipping $25
1x walbro 342 $132
Total $803
steve if i get the id1000's do i need the height adaptors to run them with A/M fuel rail?
coz i would be down for a set of them!
sorry I'm not sure, I'm trying to find out
every time i think i have my head around injectors i find out i don't :D
i dare say you will but don't quote me :)
hey steve,
just double checking these will fit np with the stock plenum?? and ive already got a adjustable nismo fpr, so should be ok.
e85 here i come :)
oh, if its just a connection issue, should be ok, as there is a rubber tube between the rail and fpr, im sure ill work something out.
and since your going the e85 way, do only the three caltex servo sell e85?? i know there is that race shop that has it, but do any other servos??
there is a Liberty on Tapleys Hill Rd
are you familular with Simon Micheal mores S14 drift car with RB25 NEO engine
with a GT3076 and these 80lb/h injectors @ 19psi he made 397 rwkw on a hub pack dyno
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
