  • Replies 163
Posted Images
PM's sent thanks guys we cant submit order till all payments are in or i have confirm person doesn't want injectors
it looks like we only have the 5 buy price on 80lb injectors unless someone comes in on the last 2 days for the 1000cc
when replying to the payment PM i send out please give delivery address details thank you
ok guys LAST day is here i will PM those people who haven't already paid or PM'd me last thing tonight before i go to bed and will try to have everyone's money in by Tuesday next week
due to the supplier's wife giving birth it has been hard to get in touch with him today and being a Friday not much would of happened also
on page 1 i said there would be a 2 week turn around i feel confident we can still keep this time frame
as soon as payment is made i will post up again
order was submitted last night and i spoke with the supplier today as to not send wrong parts we are double checking against his knowledge bank but unfortunately he has nothing in there for NM35 injector harness's
does anyone know what harness type they use EV1, EV4 ?? or can post up a picture of an NM35 injector and harness
The harness has the knock sensor coaxial running with it, so it cant be just swapped over. The stock injectors have a Denso plug so you would need short adapters like this to connect to whatever the new plug is. Does he have a listing for VQ35 or 350z/v35?
I just bought a new plug and soldered the pins on. Much neater but quite fiddly.
If the 1000cc injectors are the same as the ones I just fitted, they will need to remove the spacers under the rail and bolt them right down as they are around 3mm shorter.
The 610's fit well if you have a plenum spacer as they are 15mm longer, you will have to bend the fuel rail a bit though.
thanks heaps for that information Scott
he can do a plug that you strip your plug and re pin it
does the Vq35 and 350z/V35 use the same plug adapter
in discussions with supplier will have news shortly the NM35 injector harness is giving us some grief
What would be a better option is if we supply a plug kit (pictured below) and what the buyer then does is cut off their old plug on the loom, and join this new plug up.
ok last update direct quote from supplier just in, Dunc and Andy i am happy to pay the $24 before the transaction clears so we can try and get them here ASAP, btw i have had to pull out of this group buy as my car needed castor bushes so not even getting cheap injectors :( but thats ok Tuff Car Parts will look after me later down the track
i also couldn't speak more highly of Tuff Car Parts as the $42 wiring harness was only for the EV1 style injector plug but as there was some confusion he has accepted to do them @ the price that was quoted at his loss of $120 over the whole group buy
Those who have missed out in the Tuff Car Parts Group Buy can contact Justin on his eBay store and speak of the group buy for a small discount BUT you need to contact him before purchase
Thanks Steve, no probs! Just to confirm, below is the order as it now stands:
Only things outstanding is the Stagea guys just need to pay $24 extra each for the wiring plug kits.
I will confirm with total + freight + insurance tomorrow, will keep you updated!
Guest
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
