just wondering how many people in the forums are from this lovely town?
Well there's me in town..... infrequently. There's heaps of nice clean Skylines around I reckon, saw 2 very tidy examples today, silver job & a white one down the main drag about 2-ish, I've been outta town for a while but there were 4 Stags (counting mine) around that I knew of last time I was in town....a 260RS out in Kambodia as well. Dunno if they are all still around or all on the forum or active but. Problem is work rosters. nightshift, 8 & 6, month on week off..fifo, dido..satphone comms in the boonies.....whatever. One of these days I would like to take a run with the local Nissan boys to the Broad Arrow Tavern or Widgiemootha Roadhouse or just somewhere, for a burger (excuse for run/pics/say gidday)
Work rosters rule,
Gotta grab it while you can,
Cheers GW :miner: out.
https://www.sau.com.au/forums/topic/352880-kalgoorlie-yo/#findComment-5657332
a kalgoorlie skyline cruise would be sweet, there are a few nice skylines around
i have a couple mates with some nice ones and i've recently met a guy with a couple sweet r32s
not many people know this but a HPI feature car now resides in kalgoorlie,
its a red 4 door r34 "gtr" built by C-red in perth, i saw that up close the thing is beautiful.
then i know of a few other imports too
https://www.sau.com.au/forums/topic/352880-kalgoorlie-yo/#findComment-5660206
My mum worked in a medical clinic at Kalgoorlie last year.
I've being there about 3 times, driving there is a pain in the ass especially when you are driving around in a white Camry... the most boring-est car in the world.
Not to mention on the way there, from the 1/2 way point (from Merredin onwards), the over-taking lanes disappears all together & overtaking 3 stage road trains is annoying as hell in a underpowered Camry.
The only import I've seen while I was there was a Soarer, otherwise all I see is a bunch of bogans driving around in their Chevy badged bogandores.
Edited by Mayuri Krab
https://www.sau.com.au/forums/topic/352880-kalgoorlie-yo/#findComment-5660261
Hey I have that issue! Full Eastbear kit and Hakosuka front GT-R badge?
Edited by PewPew
https://www.sau.com.au/forums/topic/352880-kalgoorlie-yo/#findComment-5669714
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
