Just asking what everyone uses for fluids for the following;
Brake fluid
Coolant/radiator
Power steering
Transmission
Does anyone use anything other than oem/Nissan fluids? eg royal purple transmission fluid etc
Is it wise / good to use branded fluids such as RP for these?
Any benefits or cons to using fluids other than Nissan oem fluids?
I might need to change some of mine (apparently needs to be done at 60k kms) according to the manual I have.
Edited by ezy03
https://www.sau.com.au/forums/topic/352909-service-fluilds/
checkout this write-up that Nate did (should really be a sticky by now..) It's quite helpful:
http://www.skylinesaustralia.com/forums/topic/346667-servicing-your-v35-list-of-whats-needed/page__p__5580718__hl__servicing__fromsearch__1#entry5580718
On a side note I've tried a couple of brake fluid brands and found Motul Dot 5.1 to be the best (done occasional track work here n there) - AP Racing isn't bad either. For your AT fluid use Nissan Matic J ATF.
https://www.sau.com.au/forums/topic/352909-service-fluilds/#findComment-5656985
i guess ill be using Nissan Matic J for the transmission
any recommendation or favorites that you guys use for those (Brake fluid Coolant/radiator Power steering + diff oil, i forgot to mention that above).
If you have 5AT then use nissan oil but for the trans but for everything else see my post that diabolique nicely posted.
https://www.sau.com.au/forums/topic/352909-service-fluilds/#findComment-5657292
guys is the 4quarts for the auto fluid just for a drain and refill or full flush? - which is best to do? im getting mixed answers here and there apparenty the 4quarts is for a quick drain and refill (can someone confirm that for me) and 16quarts for full flush (again someone confirm or correct it). my car is at 60k kms atm. semi-auto 03 coupe.
https://www.sau.com.au/forums/topic/352909-service-fluilds/#findComment-5661460
Nissan dealer that has parts store, got mine at Liverpool 5 ltr for 80 bucks. On g35parts they sell it for $9.99usd per quart but I dunno about shipping. Also im only going to do 5 ltrs cuz I think that's all that's needed at this service (going off the service post and a kit that riversideinfiniti is selling)
https://www.sau.com.au/forums/topic/352909-service-fluilds/#findComment-5668136
Thanks mate
https://www.sau.com.au/forums/topic/352909-service-fluilds/#findComment-5668281
