Hey mate, this is on carsales atm, might have to get your mate to try and work out a deal
http://www.carsales.com.au/all-cars/private/details.aspx?R=8866850&YearFromShort=1639&__Qpb=true&Cr=0&__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pCar_Model_String|0&keywords=&YearToShort=1676&__N=1216 1246 1247 1252 1282 4294963593 4294963846 1639 1676&silo=1011&seot=1&__Nne=15&trecs=788&__sid=12CFFFFB1B15
https://www.sau.com.au/forums/topic/352931-wtb-r34-gtr/#findComment-5666044
Might be worth getting the vin BNR34003026 checked on that car as it doesn't look like a genuine v spec and non v spec models usually sell for 4 to 5 thousand cheaper than v spec models. Alsp that vin number would suggest its an early 99 model and not a 2000 model. The guys would be able to confirm it on the "vins you want fasted" thread. If it turns out to be a v spec then the rear and front diffusers are missing and it definately has a non v spec speedo installed.
All good negotiating points to try and get it a bit cheaper if that is the one he likes.
cheers.
Edited by thatlbeme
https://www.sau.com.au/forums/topic/352931-wtb-r34-gtr/#findComment-5674128
I've talked to this guy and the price isn't very negotiable.
He's supplied the VIN, I've put it through Nissan FAST and I can confirm it is NOT a vspec.
I don't know why he claims it to be one, it doesn't even have a vspec sticker in the very least.
No front/rear diffuers...etc.
I suspect he got sold it as a vspec and got rolled, so now wants to sell it as one.
It's a 1999 non-vspec model, 2000 models should have black seats not grey.
Oh, and I also pointed out the fact that I put his car through Nissan FAST and suggested that his car is not a vspec, hoping he'd negotiate the price. NOPE! I was still interested in buying a non-vspec car, but he won't budge. Seems overall dodgy to me.
Edited by EVOIV
https://www.sau.com.au/forums/topic/352931-wtb-r34-gtr/#findComment-5677132
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
