Definitely less pokey. AC is fine since it was regassed just before I bought the car. Even with the hdi intercooler the heat really takes the oomph out of the engine. The difference was very discernible when we had the hot days early last week and the cooler last couple of days.
https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657221
The stock ecu drops timing out heavily on hot days and ramps up the fuel, its what Nissan had to do to save an engine that's being thrashed on a hot day. If you can lower the intake temp you wont notice it as much.
https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657247
So was the bigger intercooler suppose to help with the hot weather?
with the last 6-7 day's we have had in Sydney it would not matter what IC you had....you would still be see a considerable change in drivability!.....I'm just glad I no longer have my standard one!
https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657535
Craig,,, You NEED water spray...... mmmwwwwwhhhhaaaaaaa :whistling:
https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657614
You can try a cooling spray on the IC. Jaycar have a kit.
On M35's the intake air temp sensor is in the AFM. You could put ice in the intercooler and the ECU would still see the same temperature. Ice in the airbox would work...
https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657693
Last time I checked dry ice made CO2... not combustible- but cold! So it would prob make a good combustion extinguisher! :thumbsup:
Maybe one of those massive dry ice chamber/intercoolers that the dyno cars/drag cars run!!!
Do they sell a Temperature Cut defender...?:rolleyes:
https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657746
In the R33 manualon page EN13 it shows where the temp sensor is. It looks like it is in the T/B. I could be wrong, but if this is so a spray unit on the fmic would help in the C34s.
Edited by 66yostagea
https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657880
most definitely would work me thinks.....and probably quite well!
https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657930
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
    • thanks, will conduct myself accordingly. i unfortunately put about 150 miles on the car before reading this thread again, however no PS issues, and definitely no turbo issues. it spools normally and still feels fast to me, probably because my previous car was an N/A auto sedan...gonna go fix the PS vacuum line though lol. safe to say, got what i came to this thread for. thanks
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
