Tonkachow Posted February 5, 2011 Share Posted February 5, 2011 Just curious at how the Turbo M35 car's are handling the heat at the moment. Is anyone struggling in any areas. Air con keeping up. Diff and oil temp behaving as expected or worse etc. Link to comment https://www.sau.com.au/forums/topic/352941-curious/ Share on other sites More sharing options...
Paramour Posted February 5, 2011 Share Posted February 5, 2011 Mines not as pokey as it normally is, but expected. . AC could do with a regas, has anyone needed to regas their M35 at all. . Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657189 Share on other sites More sharing options...
Sunkist Posted February 5, 2011 Share Posted February 5, 2011 mines on stands with no turbo playing in the flooded water hahah Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657204 Share on other sites More sharing options...
ironpaw Posted February 5, 2011 Share Posted February 5, 2011 Definitely less pokey. AC is fine since it was regassed just before I bought the car. Even with the hdi intercooler the heat really takes the oomph out of the engine. The difference was very discernible when we had the hot days early last week and the cooler last couple of days. Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657221 Share on other sites More sharing options...
scotty nm35 Posted February 5, 2011 Share Posted February 5, 2011 The stock ecu drops timing out heavily on hot days and ramps up the fuel, its what Nissan had to do to save an engine that's being thrashed on a hot day. If you can lower the intake temp you wont notice it as much. Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657247 Share on other sites More sharing options...
Jetwreck Posted February 5, 2011 Share Posted February 5, 2011 Completely f#%clef!!!...not mention every thing else.....come On winter! Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657261 Share on other sites More sharing options...
zei20l Posted February 5, 2011 Share Posted February 5, 2011 yeah mine too. sluggish as hell plus VERY high intake temps, and water temps too. Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657387 Share on other sites More sharing options...
ironpaw Posted February 5, 2011 Share Posted February 5, 2011 So was the bigger intercooler suppose to help with the hot weather? Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657483 Share on other sites More sharing options...
66yostagea Posted February 5, 2011 Share Posted February 5, 2011 You can try a cooling spray on the IC. Jaycar have a kit. Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657502 Share on other sites More sharing options...
Tonkachow Posted February 5, 2011 Author Share Posted February 5, 2011 Cool. So nothing really out of the ordinary. Heat reduction is def one of the biggest challenges I often think about more then most mods in cars. Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657523 Share on other sites More sharing options...
Jetwreck Posted February 5, 2011 Share Posted February 5, 2011 So was the bigger intercooler suppose to help with the hot weather? with the last 6-7 day's we have had in Sydney it would not matter what IC you had....you would still be see a considerable change in drivability!.....I'm just glad I no longer have my standard one! Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657535 Share on other sites More sharing options...
andy65b Posted February 6, 2011 Share Posted February 6, 2011 with the last 6-7 day's we have had in Sydney it would not matter what IC you had....you would still be see a considerable change in drivability!.....I'm just glad I no longer have my standard one! Craig,,, You NEED water spray...... mmmwwwwwhhhhaaaaaaa Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657614 Share on other sites More sharing options...
Sunkist Posted February 6, 2011 Share Posted February 6, 2011 Craig,,, You NEED water spray...... mmmwwwwwhhhhaaaaaaa i was gonna do this lol Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657618 Share on other sites More sharing options...
scotty nm35 Posted February 6, 2011 Share Posted February 6, 2011 You can try a cooling spray on the IC. Jaycar have a kit. On M35's the intake air temp sensor is in the AFM. You could put ice in the intercooler and the ECU would still see the same temperature. Ice in the airbox would work... Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657693 Share on other sites More sharing options...
Dunc Posted February 6, 2011 Share Posted February 6, 2011 Ice might have moisture related issues.. dry ice on the other hand... Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657730 Share on other sites More sharing options...
Daleo Posted February 6, 2011 Share Posted February 6, 2011 Except the resulting release of co2 as the dry ice melts... Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657741 Share on other sites More sharing options...
PN-Mad Posted February 6, 2011 Share Posted February 6, 2011 Last time I checked dry ice made CO2... not combustible- but cold! So it would prob make a good combustion extinguisher! Maybe one of those massive dry ice chamber/intercoolers that the dyno cars/drag cars run!!! Do they sell a Temperature Cut defender...? Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657746 Share on other sites More sharing options...
66yostagea Posted February 6, 2011 Share Posted February 6, 2011 (edited) On M35's the intake air temp sensor is in the AFM. You could put ice in the intercooler and the ECU would still see the same temperature. Ice in the airbox would work... In the R33 manualon page EN13 it shows where the temp sensor is. It looks like it is in the T/B. I could be wrong, but if this is so a spray unit on the fmic would help in the C34s. Edited February 6, 2011 by 66yostagea Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657880 Share on other sites More sharing options...
Sunkist Posted February 6, 2011 Share Posted February 6, 2011 (edited) Edited February 6, 2011 by AaronNM35 Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657929 Share on other sites More sharing options...
Jetwreck Posted February 6, 2011 Share Posted February 6, 2011 In the R33 manualon page EN13 it shows where the temp sensor is. It looks like it is in the T/B. I could be wrong, but if this is so a spray unit on the fmic would help in the C34s. most definitely would work me thinks.....and probably quite well! Link to comment https://www.sau.com.au/forums/topic/352941-curious/#findComment-5657930 Share on other sites More sharing options...
