Make/Model: R33 Skyline Gts-t
Year: 1996
Kilometers: 96,000
Transmission type: Manual
Engine: RB25DET
Colour: Black with purple flip
Modifications: 3 1/2 cat back exhaust,
Zeal height adjustable coilovers,
17" Rays CV Pro's fronts 8.5" +33 rears 9" +38 resprayed black,
Extreme HD clutch,
FMIC,
Profec B Spec II EBC,
Bosch 040 fuel pump,
GTR rear wing,
oil cooler,
splitfire coilpacks,
NGK platinum spark plugs,
DBA slotted brakes on front,
Mspec radiator,
D2 front control arms,
Apexi POD,
Roadworthy Certificate: N/A
Accident History: none
Asking Price: $14,500 ono
NO SWAPS/ TRADES
All reasonable offers considered
Contact Details: 0407 747 386 or PM
Other Comments: Viper car alarm with remote start and gear switch,
Nismo clear side indicators,
JVC CD player,
SONY front splits,
gear and brake boots retrimmed,
calipers painted in VHT blue,
front and rear lights clear coated,
tinted windows,
shaved boot lock,
genuine Skyline floor mats
Bought the car in 2005 and have looked after it over the years, car had 48,000kms when I purchased it.
Is a very clean car, hasn't been driven very much in the last year as was my weekend car. Work has taken away my weekends, better to be sold than sitting around wasted
Car is owned outright
Service history
Please no bad comments, if your not interested please don't comment
post-23924-0-99284500-1296908602_thumb.jpgpost-23924-0-92455500-1296908726_thumb.jpgpost-23924-0-86588600-1296908757_thumb.jpgpost-23924-0-53587500-1296908862_thumb.jpgpost-23924-0-08483100-1296908949_thumb.jpgpost-23924-0-15353000-1296909008_thumb.jpgpost-23924-0-44161900-1296909151_thumb.jpg
Edited by (OO Black 33 OO)
https://www.sau.com.au/forums/topic/352951-sa-r33-gts-t-series-2/
  • 3 months later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
