2 spoolimports oil drain kits just arrived.
Looking on line, and this site i saw people placing the return on the right and some on the left front side of the oil pan. Witch side should i place the return line, looking at the engine from the front.?????
Thanks mates.
https://www.sau.com.au/forums/topic/352967-spoolimports-oil-drian-kits/
ok, my old GTR i ran the oil drain to the rear turbo oil return on the passenger side as i was running a single turbo and had a spare oil drain spot,
on my current GTR i have the oil drain running to the drivers side and have a fitting welded into the sump. both setups work however i noticed that the oil return on the passenger side made my engine breath a little heavier
What do you mean by breath a little heavier. do you mean make more power, or just rev faster????
but it looks like i will be placing it on the left with a weld in fitting, after i installed restrictor and drill out head and block oil return gallaries. to much oil in the head has plagued me for a long time and this build i will get on top of it
Thanks Mate.
cheers
Edited by MJTru
You have to hook it into the turbo oil drain hose. I have this kit on my car, just need to hook the hose in and i'll be sweet
I believe your thinking of the driver side return because odds are if you bought the spool drain kit, they bought the spool sump ( im referring to your info that you looked up). I gave spool a buzz and asked about this drain return. I was told its just a "generic oil return"
Edited by r33cruiser
Thanks Mate.
cheers
what i mean is the engine seemed to have blowby once i fitted the rear drain to the passenger side, basically the oil return does return oil from the head to the sump but it also is a passage for crankcase pressure to make its way back up to the head.
This is interesting!
I had them set up on the driver side on my other builds but figured on my current build to try on the pass side or both pass side driver side thinking that the cranks rotation would help the drain flow as the crank spins clock wise if looking at the front of the engine. Did you notice this from a before and after or was there other things to consider with your build when you did your drain?
Thinking if it were on the driver side of the sump the rotation of the crank would not help the drain drain the oil into the sump. kind of a total reverse to what your saying.
i rebuilt my RB26 in my last GTR, then found out about all of the oil control issues, so i stripped it back down, got the crank collar done(but left pistons in the cylinders), fitted oil restrictor, new tomei pump, rear oil drain from the head,
and since i put it back in it was breathing heavier
put it back on the shelf.... doesn't do much, been covered heaps of times.
I pulled the return off ours and ran it into a coke bottle and.... well nothing happened.
Can you elaborate on this status? Was this tested on the track with G forces involved or on the dyno? My car has no issues at all on the dyno with blow by. On the track is a totally different story.
I will be pulling my motor out soon as I have waaay too much oil in the head. I have a 1.5mm restrictor and a Reimax pump that is currently regulated to 120psi @ anything above 3000rpm. My play is to drop the pressure to around 75-85psi max. I was also going to put a head drain in, but I figure reducing the flow by 30-40% should make a profound impact on the amount of blow by.
For the record all oil returns should be on the passenger side due to crank induced vacuum. Just as factory have designed it.....having said that a 2J is the other way around.....
Edited by BoostdR
I read the entire oil thread. Seems to be a 50/50 on people who think that it is a drain or a vent. Regardless, if not doing the rear drain then the sump should still vent via the separator/catch tank. With all the heated debate, I am just going to install two -10an fittings on each side of the sump above oil level. Then, conduct my own tests and use what I believe works better. Find out if its draining under load or helping the engine breath better. That way I have a drain/vent for the head and the primary catch tank and conclude what side is more appropriate once I find out if its a drain or not.
Edited by RB30 Ceffy
but did you run it for 5 minutes at 6000rpm for the test?
if you want a vent from the bottom end, venting via the dipstick would make a lot more sense than sending it to the head, then out the breathers.
because you need at least a -10 hose for it to be effective. you are completing an air circuit which is how the engine was designed. vacuum and pressure in different areas assisting the oil to be pushed back to the pan and pick-up. Sending it to the rear of the head the pressure has to travel along the camshafts before entering the cam baffles and out the head. This helps the factory oil drains do their job.
how do you train the air to go up the hose but not go up the drains? sounds tricky.
I know the other thread has been done to death....but if you put a hose high in the head, eg in the welsh plug, of course you are over the oil level and it won't drain oil.
Do it properly (large drain, and at the bottom of the head) and I sure it would work properly.
But in 99% of cars it is a moot point...they aren't working hard enough to make a difference.
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
