2 spoolimports oil drain kits just arrived.
Looking on line, and this site i saw people placing the return on the right and some on the left front side of the oil pan. Witch side should i place the return line, looking at the engine from the front.?????
Thanks mates.
https://www.sau.com.au/forums/topic/352967-spoolimports-oil-drian-kits/
ok, my old GTR i ran the oil drain to the rear turbo oil return on the passenger side as i was running a single turbo and had a spare oil drain spot,
on my current GTR i have the oil drain running to the drivers side and have a fitting welded into the sump. both setups work however i noticed that the oil return on the passenger side made my engine breath a little heavier
What do you mean by breath a little heavier. do you mean make more power, or just rev faster????
but it looks like i will be placing it on the left with a weld in fitting, after i installed restrictor and drill out head and block oil return gallaries. to much oil in the head has plagued me for a long time and this build i will get on top of it
Thanks Mate.
cheers
Edited by MJTru
You have to hook it into the turbo oil drain hose. I have this kit on my car, just need to hook the hose in and i'll be sweet
I believe your thinking of the driver side return because odds are if you bought the spool drain kit, they bought the spool sump ( im referring to your info that you looked up). I gave spool a buzz and asked about this drain return. I was told its just a "generic oil return"
Edited by r33cruiser
Thanks Mate.
cheers
what i mean is the engine seemed to have blowby once i fitted the rear drain to the passenger side, basically the oil return does return oil from the head to the sump but it also is a passage for crankcase pressure to make its way back up to the head.
This is interesting!
I had them set up on the driver side on my other builds but figured on my current build to try on the pass side or both pass side driver side thinking that the cranks rotation would help the drain flow as the crank spins clock wise if looking at the front of the engine. Did you notice this from a before and after or was there other things to consider with your build when you did your drain?
Thinking if it were on the driver side of the sump the rotation of the crank would not help the drain drain the oil into the sump. kind of a total reverse to what your saying.
i rebuilt my RB26 in my last GTR, then found out about all of the oil control issues, so i stripped it back down, got the crank collar done(but left pistons in the cylinders), fitted oil restrictor, new tomei pump, rear oil drain from the head,
and since i put it back in it was breathing heavier
put it back on the shelf.... doesn't do much, been covered heaps of times.
I pulled the return off ours and ran it into a coke bottle and.... well nothing happened.
Can you elaborate on this status? Was this tested on the track with G forces involved or on the dyno? My car has no issues at all on the dyno with blow by. On the track is a totally different story.
I will be pulling my motor out soon as I have waaay too much oil in the head. I have a 1.5mm restrictor and a Reimax pump that is currently regulated to 120psi @ anything above 3000rpm. My play is to drop the pressure to around 75-85psi max. I was also going to put a head drain in, but I figure reducing the flow by 30-40% should make a profound impact on the amount of blow by.
For the record all oil returns should be on the passenger side due to crank induced vacuum. Just as factory have designed it.....having said that a 2J is the other way around.....
Edited by BoostdR
I read the entire oil thread. Seems to be a 50/50 on people who think that it is a drain or a vent. Regardless, if not doing the rear drain then the sump should still vent via the separator/catch tank. With all the heated debate, I am just going to install two -10an fittings on each side of the sump above oil level. Then, conduct my own tests and use what I believe works better. Find out if its draining under load or helping the engine breath better. That way I have a drain/vent for the head and the primary catch tank and conclude what side is more appropriate once I find out if its a drain or not.
Edited by RB30 Ceffy
but did you run it for 5 minutes at 6000rpm for the test?
if you want a vent from the bottom end, venting via the dipstick would make a lot more sense than sending it to the head, then out the breathers.
because you need at least a -10 hose for it to be effective. you are completing an air circuit which is how the engine was designed. vacuum and pressure in different areas assisting the oil to be pushed back to the pan and pick-up. Sending it to the rear of the head the pressure has to travel along the camshafts before entering the cam baffles and out the head. This helps the factory oil drains do their job.
how do you train the air to go up the hose but not go up the drains? sounds tricky.
I know the other thread has been done to death....but if you put a hose high in the head, eg in the welsh plug, of course you are over the oil level and it won't drain oil.
Do it properly (large drain, and at the bottom of the head) and I sure it would work properly.
But in 99% of cars it is a moot point...they aren't working hard enough to make a difference.
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
