  • Replies 42
you need to get on to your mate to find out details of the build.
without receipts it is a stock motor.
saying "my mate wouldn't rip me off" doesn't really help a bunch of people who don't know you
new headgasket
piston and rings
timing belt
if you want to see it come have look .
the motor had only done 100 k before hand so its all good
Mate you have to understand that if a motor has been rebuilt. No one will touch it unless you provide a lot of details, the workshop, exactly what was done etc.
Right now you look dodgy as and even if you could come up with the specs and if I wanted a motor I wouldn't be going near this one...
This just reminds me of people who put up their car for sale with no pictures and say "stock car good condition, very good car no problems"; and that's it... I hit the 'back' button so fast rofl
Edited by RB25PWR
plus i have sold many things on here before i dont waste peoples time
if i had reciepts it would be better for me derrr
the workshop that done the work i might be able to track down his number
  • 3 weeks later...
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
