Hey all
Bought these 3 weeks ago, but they don't clear my alcon brakes because the caliper is too big.... they will clear GTR brembos easily.
Enkei RPF1 wheels. 17 x 9 +22 offset. They look the business. Brand new in boxes, never had tyres fitted.
Super light weight, weigh around 7kg each.. awesome for reducing unsprung weight = free horsepower
Priced for quick sale - $1400
In no rush to sell, if they don't sell i'll just keep them for another car.
Melbourne pickup preferred, or can help arrange courier delivery for ~$80 to eastern states.
Also have a set of brand new Advan AO50 semi slick tyres for $1800 Firm. Or buy them with the Enkei's for $3000 all up.
[email protected]
https://www.sau.com.au/forums/topic/352979-enkei-rpf1-17-x-9-22-brand-new-1400/
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
