Item Summary: 1995 NISSAN SKYLINE R33 Series 1.5 GTS25T, want a 4 door 33
Odometre: 182,000 kilometres
Asking Price: $8,000
Condition: Used
Reason for Selling: want a 4 door 33
Delivery Methods: PickUp
Contact Info: PM me
Extra Information:
i have for sale my 1995 Nissan Skyline R33 Series 1.5 GTS25T
Engine:
RB25DET Series 2
MANUAL
FMIC
COILPACKS HAVE BEEN REPLACED
AFM REPLACED RECENTLY
BRAND NEW JJR POD FILTER (WITH POD FILTER COVER AND BRACKET)
GFB BOV:RECIRC OR VENT TO ATMO
Exhaust:
FULL JASMA 3.5" MANDREL BENT EXHAUST WITH 4" CANNON
Wheels:
CLASSIC JAPANESE RS-5 SUPER STREET 17"S
235/45/17 FRONT
255/45/17 REAR (SOME DISH)
TYRES HAVE ONLY DONE 2000K'S
Modifications:
AFTERMARKET STRUT BRACE:ENGINE BAY
GENUINE SKYLINE STRUT BRACE:BOOT
SKYLINE BADGE LIGHTS UP GREEN ON BOOT(NEED ONE LED CHANGED/FIXED)
GREDDY BOOST CONTROLLER
TURBO TIMER
SARD RACING BOOST GUAGE
VOLT GUAGE
USELESS "VACUUM" GUAGE
MONGOOSE ALARM SYSTEM
Stereo Audio:
PIONEER CAROZZERIA HEADUNIT
6STACKER IN BOOT
SONY SPEAKERS FRONT AND REAR
Body
COLOUR:VELOCITY BLUE
VERY STRAIGHT
TOP SECRET FRONT BAR "SHHHHHHHH"
AFTERMARKET SIDESKIRTS
REAR PODS
What it needs
PAINT NEEDS SOME ATTENTION (CLEAR f**kED ALONG DOOR SILLS ROOF AND BONNET)
VALVE STEM SEALS REPLACED (QUOTED $450 FROM NIZZPRO:CAN BE DONE WITHOUT REMOVING THE HEAD)
PASSENGER SEATBELT ONLY GOES A CERTAIN LENGTH (TIGHT FIT:REPAIR OR REPLACE)
ALL ELECTRICS GOOD
FACTORY SUNROOF
ICE COLD AIRCON
TYRES ARE ALL ROUND
EXHAUST SOUNDS AWESOMELY MEAN
ALL SWAPS OFFERS TO BE SENT BY PM ONLY AS PER RULES
LOOKING FOR 33 4 DOOR... OR GALLARDO WITH CASH MY WAY
Edited by Blueone
https://www.sau.com.au/forums/topic/352993-1995-r33-series-15-gts25t/
PRICE DROP $7500
will take $6500 without rims and front bar
can provide stocko 33 rims and will provide slightly damaged uras front bar (same colour as car)
  • 8 months later...
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
