HI GUY'S HOW ARE YOU I WANT TO BUY A NISSAN SKYLINE R33 MANUAL TURBO FROM AND WHERE IN AUS. AND WANT START THE PRICE AT $3500 TOO $4500 AS I LIVE IN SA AND WILL COME PICK IT UP AND DRIVE IT BACK 2 WHERE I LIVE AND IF IT NEED BODY WORK I WILL STILL BUY IT ONLY CARE ABOUT IF IT DRIVE'S THAT WHAT I MOST CARE ABOUT LOL. ANY WAY PM AS IM ON HERE ALOT THANKS
  • Nope 1
https://www.sau.com.au/forums/topic/353021-wtb-skyline-r33-manual-turbo/
He said he's happy if it has body damage so it's not that far out.
I may have exactly what you are looking for. Got an assessor coming to look at mine either tomorrow or Wednesday.
It's only got a light ding on the front right, as in a scrap, but it's likely to be a totaly loss. I'll hit up the insurance to hang onto it so as long as they don't want to pillage me, it might be what you're after.
I'll let you know what the go is.
You can get tidy stock manual R33 gtst's on the online sites (private sales) for $6500-$7000 so $4500 for one with damage is not that unreasonable.
Recommend spending the money on an English tutor though - better return.
hey id sell me r33 turbo manual for $7500
its currently up for 8800 but if your seriouse about buying
and coming all the way from sa sure why not
im located in melbourne north side
let me know if your interested and i can show you pictures and such
thanks.
I have one for sale for $5000
Need it gone by the end of the month.
I have a few pics of it in the R33 picture thread.
Only damage it has is RHS rear quarter panel has a small ding, RHS front light needs replacing, and also the front bar.
If you're keen let me know.
I'm in NSW btw.
0401658880 names RJ.
ok looking at picz tomorrow of RJ skyline thank god it is black just what i want hope it look good lol if not i will come back on here and say im still looking for a skyline thanks 2 all
Edited by streetboyz
  • Nope 1
why write in capital letters????
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
