i haven't got my car dyno'd but i have no idea what kind of power it would be pushing out. just wondering what you guys think? its also 4WD too.
i got single 3" dump to 3" straight through exhaust, K+N pod with insulation in the corner to block the harsh engine heat, 10 - 11psi ( bleed valve ), 550hp fuel pump, Apexi dual chamber BOV, std turbo and std cooler.
got any ideas on how much BHP or 4wkw?
i got a malpassi fuel reg to go on soon and i want to get a FMIC to drop the intake air temps
https://www.sau.com.au/forums/topic/35303-rb20det-power-est/
to give you an idea..
RB20det (silver top - R32 gtst)
3 inch exhaust
12psi
panel filter in standard box
R33 gtst turbo
gave me 152rwkw.
One other thing.. the rb20det runs 10psi standard so you're bleed valve isn't doing much.
so with the standard turbo and 11psi with pod and exhaust, you would get something like 145-150 REAR wheel kw.
and even less at all four wheels.
go for 1 bar boost, fmic, re-mapped computer and you should be in the 160-170rwkw..
https://www.sau.com.au/forums/topic/35303-rb20det-power-est/#findComment-705574
well i am getting mine done in 3 hours time only mods include
full 3 inch zorst high flow cat 12-13 psi, pod filter,SO i am really unsure what i will be getting.. only time will tell.let u know
i had
2 3/4 inch zorst
POD w/ no shielding or CAI
FMIC
on a 32degree day at 12psi made 163@rearwheels
https://www.sau.com.au/forums/topic/35303-rb20det-power-est/#findComment-705857
