Its called a misfire mate, type Misfire, Miss etc into the search there are heaps of topics on it.
Firstly,
Check all your silicon joiners and hose clamps as if they afm is reading air but the engine is loosing it under pressure then you will overfuel and get these symptoms.
Does it blow alot of black smoke when this happens ?
secondly check the following:
Spark plugs and or gaps,
coil packs themselves,
Ignitor (sits towards the back of your engine)
How does the car feel when it hits this "wall" ?
also you could try buying some air flow meter cleaner from repco or wherever and giving your AFM a nice spray clean (DO NOT TOUCH ANY PART INSIDE THE AIR FLOW METER BODY)
Goodluck.
https://www.sau.com.au/forums/topic/353036-popping-noise/#findComment-5658205
If your not comfortable doing the sort of stuff I mentioned in the first post mate, your probably better off taking it to a workshop that has experiences with these cars if you can afford it.
Sometimes it's easy to do more harm then good.
Goodluck.
Edited by Nee-san
https://www.sau.com.au/forums/topic/353036-popping-noise/#findComment-5658302
Hey guys, when I give my car some beans at about 5k it starts popping and almost hits a bit of a wall, as if it struggles to rev more but then seems to be ok. What could be doing this? It's a s2 rs4 with a exhaust and pod that's it.
hey mate ur in adelaide right?? if you wanna bring down south one day, i can check it out for ya. prob a missfire, but could be hitting boost cut? how much boost are ya running??
mine was the same when it landed here, fresh plugs and general check over solved the issue
https://www.sau.com.au/forums/topic/353036-popping-noise/#findComment-5658315
Yeah dude in sa. Would be sweet if you could give us a hand.
I think it's running stock boost but not sure, I'll pm ya or something later today :)
Thanks mate
https://www.sau.com.au/forums/topic/353036-popping-noise/#findComment-5658530
Definitely start with spark plugs, if the car is a fresh import or being serviced by a mechanic with little experience on turbo imports it will probably have the wrong plugs in it as most parts places will list iridiums with a 1.1mm gap and a heat range of 5.
You need to get some plugs in there with a 0.8mm gap and at least a heat range of 6, copper or iridium is up to you, I'd recommend coppers though.
Failing that check your coilpacks, they have an internal ignitor so no external one (like the earlier RB25's in R33's) that can cause issues. Coilpack faults are hard to pinpoint especially where it has a miss under load only, sometimes you just have to bite the bullet and shell out for a new set, but at $600+ for a new set of splitfires, it's a big bullet to bite.
https://www.sau.com.au/forums/topic/353036-popping-noise/#findComment-5658561
    • Nah, new members can't post pics until they reach a certain post count. If I get a chance I'll promote you to full member, if @Prank or someone else doesn't get there first.
    • Drilled the rubber out on a slow speed and it didn't catch much at all. Probably only half a dozen holes was enough to shred the rubber and it dropped off easily leaving the inner sleeve behind. Will tackle that later
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
