Increasing Boost
airbox
 Share
i have been thinking about giving the car a mild boost by bypassing the solenoid with an adjustable bleed valve or the other option is to try and drill out the solenoid by 1mm or so to increase the bleed off slightly. Has anyone tried this way? Seems a simple cheap way of increasing boost to me.
Do a search. Theres a huuuge thread on how to get high boost mode on the standard solenoid. Remember the highest you can go on the stock turbo is about 12psi. Higher than that and you'll seriously shorten the life of your turbo.
cheers, have already done the earthing mod about a year ago. Am hitting about 7psi now and that is with a supposed r33gtst actuator that I got off a spare turbo I bought.. I know the gtst actuator is meant to be higher spring rate to achieve more boost but I can't see it made any difference to the standard stagea one. I tried to just join the hoses that go to the solenoid together but that gave me big spiky boost so I reckon that if I restrict the airflow to just above what flows through the solenoid then I should get a bit more boost. If I had a proper 10psi actuator then I wouldn't need the solenoid at all as there would be no need to bleed any air off.
Get a manual bleed valve, the turbo tech ones work well. Get rid of the solenoid all together then just run the actuator with the boost controller!
Edited by turbo x-trail
R33 actuators don't run more than a stagea one, they are still a 5psi actuator with the solenoid bleeding it of to 7psi.
Cheap options are to get a manual boost tee, the turbotech ones are highly recommended. Or get a R32 GTST actuator as Tom said, they are 10psi.
I used to run the earth system, hooked up with a switch so I could run either or. After fitting the front plenum I went manual, set at 10psi. The increase in power was quite remarkable.
$30 turbotech boost T vs frigging around?!?!
Boost T pretty clearly the winner.
+1.
why dont you modify the actuator. weld a spring onto it!
we did this to a 8psi actuator as we could get a replacement actuator.
runs a clean 20psi flat line! - takes abit to get it right though!
welding a spring onto the actuator is just a little bit too backyard for most people, that on top of unpredictable results, fragile stock turbo, and the option of a $30 manual boost tee that comes highly recommended, why would you risk it.
lots of cowboys about these days :stupid: ,
but each to there own :whistling: ,
most guys do it as it should be done :thumbsup: ,
i guess then they will start saying FUEL use is up only get 250/300 a tank :unsure::wacko: lol
cheers, I think I will look for an r32 actuator and do away with the solenoid. In the meantime I think I will just bypass the solenoid with one of these.
http://cgi.ebay.co.uk/Brass-lockable-2-port-bleed-valve-Boost-Control-/270583539142?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f000925c6
and start off with it virually closed until I get to about 9 or 10psi. Seems easier than the turbotech and no replacing the Tee either.
What I am going to do with the solenoid signal is just for a bit of bling. Solenoid signal to a relay, relay turning on and off one of these.
http://cgi.ebay.co.uk/Universal-12-Volt-Windscreen-Washer-Pump-Water-Bottle-/270509676174?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3efba2168e
and running to a atomiser jet ( spray can nozzle ) firing up into the r34gtt intercooler That I have fitted. Just need to find a space for the bottle. Should only come on when the high boost mode would be on!!
How is doing all that easier than fitting a $30 part to a couple of hoses?
The turbotech is not technically a bleed valve, it will only send air to the actuator at your selected target boost.
I don't trust them on higher boost applications but for a stocker they are definitely the biz.
i think people missed this.
you will be changing between springs to get your desired boost.
also running your desired boost and not having a boost controller for a cop to see is the benefit..
everyone to their own.
I do also agree
$30 for a turbotech manual boost controller and a slice in the vacuum line is the easiest simplest option!!
I had one of these! works much better than the other products out there.
it's easier I reckon cos I would just replace the solenoid with the bleed valve, nothing else. start off with it closed for 5psi and crack it open a bit at a time until I get about 9psi. The turbotech one is more expensive and you are also changing the Tee piece and if as you say it works like a ball and spring type one, then the operation is different to standard where air is bled away to keep the pressure at the actuator down. I'll let you know how I get on!!
I fitted an r32 actuator to my car - really straight forward swap, and much more consistent boost than any bleed valve can achieve. Highly recommend it. Just make sure you unplug the factory bleed if you do (or it will spike to 14+ psi..)
 Share
    • FWIW, I've always found Toyota A/Cs to be much colder than Nissan ones. Even that 2024 Nissan X-Trail (that VW Australia lent to me), the A/C isn't as cold as other base model Toyota Corollas/Camrys, etc. Maybe Toyota A/C compressors are superior?
    • Hurry while stocks last! 🤣 13% points redemption on this $6000 Mont Blanc "James Dean" ballpoint pen at Yodobashi Camera in Umeda, Osaka
    • It's not that at all....I just love the R chassis too much to keep racing it! Absolutely impossible to fix the damn thing if I bend it.... That last off I had (when I neglected to do what Kel said), we removed a gum tree with the side of the boot....needed a new rear quarter, boot lid, floor straighten, rear bar, front bar, both front guards, radiator, bov return and I still haven't got it back for a proper alignment to check it is actually straight again). There are just too many ways in tarmac rally to do significant damage to a car that you can't really get parts for.
    • Now I'd said earlier I'd checked the fuses, and per @Stick180's suggestion I checked them all again. The check was to use the multimeter in continuity mode on the top of each fuse where the little metal tabs are available for that purpose. All good....except that very "A/T Control" fuse was actually blown when I pulled it out and looked at it. Put it back in, tested it again, there is continuity to both sides even though the fuse is blown. I'll need someone smarter than me, but my suspicion is that I was getting a circuit through a power supply, through an incandescent globe somewhere, to earth, to the shorted wire and back to the other side of the fuse, making it look like the fuse was OK when it wasn't....please anyone that understands this f**kery explain it to me. Bottom line....that suspicious purple/white wire, in an undamaged factory loom, that goes to the the wrong place in the fuse box has a dead short to earth, confirmed from both ends.  How a single wire in a factory loom can be shorted, especially the best protected loom in the whole car (underneath the top of the dash) is going to keep me awake at night because surely whatever caused the damage has (or will) damaged other wires in that loom too. So, to finish this long and sad story....cut the purple/white wire where it exits the fuse box, ran a new wire from there to the ECU loom pin 31, fired it up and drove happily into the sunset. Only 4 days of head scratching and peering into footwells to get me there. Another collection of wire removed (in addition to the earlier photo) and a bunch of 10a fuses that gave their lives for the trouble shooting....thank you for their service.  And, since the car was in the shed I resealed the cam cover (first time I've ever had a new seal leak on an RB, but the Stagea is that kind of lucky), and I put in the boost doc cam splash plates to try and turn down the blow by a bit while I was there. Which, was all good because it also let me find the slow coolant leak, turns out it was from the turbo water supply which I nipped up again (the banjo bolt got new washers, and I tightened the hose end and hose to banjo fitting while I was there)
