**Out of Interest**
No I'm not interested in a swap unless that swap is your money for my car.
1987 Z31 200zr
Converted from RB20 to RB26
Dyno sheet proven 450+ RWHP
Specs -
Nismo Engine mounts
Sard - Fuel Regulator
SARD 700cc Injectors
C's Genuine Short Shifter
Nismo Oversize Clutch Slave Cylinder
Tomei Pon Camshafts 260 degree 9.15 lift
Tomei Adjustable Cam Pulleys
R34 RB25DET Gearbox
OS Giken Push Pull Converter
NGK iridium Spark plugs
Kyb Gas Adjust Shock absorbers
Kings Low Springs Front & Rear
Bendix Ultimate Brake Pads
Redline Diff and Gearbox oil
DBA 4000 series Slotted Rotors Front & Rear
R32 GTR Front Calipers (rebuilt)
Z31 Rear Calipers (rebuilt) last week
Braided Turbo Oil and Water lines
Bosch 044 External Fuel pump
Surge Tank (being pumped by standard pump)
Gates Timing Belt Kit
Tomei Expreme Dump Pipes
Tomei Expreme Manifolds
Axis 19" Wheels with Kumho KU31 Tyes
Garret GT2860R-5 x 2
89 Z31 5 stud front Hubs
PWR Custom 55mm Low Pressure Drop core Cross flow Radiator
Custom Drive Shaft
Custom Fuel hoses
Goodridge Braided Brake Lines
Greddy 1.2mm metal head gasket
Manley valves
Supertech valve springs
Lifter Shims
Custom Aluminum intercooler piping
4" Thick hybrid Inter cooler
3 inch joins from dumps into 3.5" Mandrel Bent Exhaust
Custom Aluminum radiator piping
Ross Nexus harmonic balancer
Davies Craig 16" thermo fan
Oversize Aluminum Fuel Rail
custom 3 way aluminum tank for Radiator overflow, oil catch and window washer liquid
820cca battery
Custom made wiring harness
z32 Speedo Sender
Greddy AiriNXII pod filters
ARP head studs
Wolf v500 ECU and sensors
Custom Alarm with immobilizer and remote central locking and built in turbo timer
OS Giken tripple plate Clutch Rebuilt by Nick Performance Clutch
OS Giken Flywheel Machined by Nick Performance Clutch
Custom Enlarged Sump to Hold 5L of oil
Custom Oil Pickup
Custom Gearbox mount
Splitfire Coil Pack
HKS CDI ignition
Custom Laser cut Dash
Fuel PSI gauge
Boost PSI gauge
Oil PSI gauge
Water Temp gauge
Oil Temp gauge
Fuel Level with Warning
Tachometer 10k with built in Shift light 200zr writing
Speedometer 260kmh 200zr writing
Steering rack rebuilt with bigger seals by ultimate power steering 2 weeks ago
Alpine 6" fronts
Alpine 6" Rears
JBL 12" 1600Watt Sub
Custom boot enclousure
Lanzar 2400Watt amp
Arnell 400Watt amp
JVC Head unit
Custom Respray Black with silver pearl only 2 months ago
Custom air vents fiberglass molded into front bar
3.5" Mandrel Bent Exhaust done at Fat Pipes
Twin Cannon mufflers
Custom Red and black interior
20OZR number plates
Serviced Religiously every 5000k with Penrite SIN or HPR with no exception
All work done by either Millenium Motorsport or myself and tuned by Carlos at Millenium Motorsport.
Engineered, Mod Plated etc over 100K total spend on parts and labour
Did i mention its hell fast and leaves XR6T's for dead? it drifts alright for what it is too :)
Anyone keen on the rarest and coolest thing since sliced bread?
email me on [email protected]
https://www.sau.com.au/forums/topic/353057-rb26dett-z31-200zr-eoi/
how much... well what i want for it and what im going to get or someone is willing to pay are two completely different things.
Ideally low 30k mark would be nice but i think I've got bucklys chance of getting it..
Offer if you interested?
Holyshit that's a sxc dash can I and how do I get that in my z31 vg30det the sheer beauty is actually bring tears to my eyes, my pregnant dog seen it and had its pups immediately....lol seriously amazing man great job :)
HOOOOOOOOOLLLY SHIT, This is by far the most amazing thing i have ever seen.
I used to own a Z31, always wanted to drop an RB into it but gave up and bought my GTR instead.
Hope if/wen you sell this it goes to a good home, it looks amazing :)
It cost u more then $1000 :) is it still a z31 dash I'm seriously interested in atleast gettin that cluster wld that b possible?
Well, I'm not going to pull my dash out and sell it to you if thats what you're asking.
LOL its all custom and not stock Z31
If you want to have a dash the same as mine the cost is upwards of $5000
That's for gauges, laser cut dash, lights, wiring etc
Edited by str00th
I thought so...
Well i saw a clean RX7 rims and kit with only 400hp for 60k maybe thats a better price range?
I have it listed on the American 300zx forums and they seem to think 40k is cheap and some are interested
Thats a weapon mate a friend has a 50th aniversary z31 and a tt z32 and a old z he is always trying to convert me over if i had the money id get this and really shoe him haha good luck with it
Holyshit 5k to get that made up my engine rebuild, new ems, turbo and front mount isnt ganna cost me that much :O but I want it so bad :(
well the gagues, last cut dash, lights, etc cost 2k or so then you got a lot of labor to install it all and wire it up
I could do it all for you for about 4k i reckon, if i had all the parts and started on a Friday night, it would be done by a Sunday night
Edited by str00th
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
