Nah it wasnt when I found it I maybe think that its was an old windscreen washer line as my car has a carbon bonnet maybe it just fell in there when they removed the old bonnet maybe not sure I'm thinking the air flow meter is had it and needs a new one and the trouble code cleared on the ecu ! Anyone in Perth got hook ups for new air flow meter ? cheers Tom
um duno man thats just how it came when i got the car mate
Yeah that is certainly an issue, really doubt it is what is happening here but it means on boost your crank case is getting pressurised, will cause excessive blow by and could blow your dip stick out if tracking the car.
You should get that stock hose on the right had side cam breather shown in the other setup, and connect it back into the intake on the right where its been blocked off.
Yea the solder joints looked pretty dry so re did them and re sealed up the air flow meter car still idles a bit funny and seem to be spitting a bit of black oily stuff out the exhaust what does that mean ? I need to take it in to mechanic ive done most of what I can at home it frustrating as the car is for sale and a guy wants it pending loan approval Ive told him its not running right but he still wants it id prefer to sell it running sweet but just see what happens if it falls through its going to mechanics to get sorted asap
Can I run two small breather filters instead of that pipe ??
thanks for everyones help
cheers
Tom
run 1 breather but on the end of a hose and have the filter under the airbox.
the black spits from the exhaust are normal, its condesation build up mixing with the soot in the exhaust.
  • 4 years later...
In order to fix your idle problem, i recommend blocking and repairing any vacuum lines, ( block any lines that lead to know were start the car listen for changes), look at a engine diagram of the vacuum lines on the net and find out were they go to, in some cases its only a matter that the carbon filter or other have been removed and its causing an air leak witch then relates to your rough idle ( it rectified my problem)
check for cracks on your coilpacks, heat spots on your leads, if degraded, replace with new ones, also remove the cover that covers the coil packs, its only their for looks really,and will trap a lot of hot air witch will lead to the same problem, just don't wash or be careful when washing the engine use compressed air and a cleaning spray, aside from that do all your basic things like air filter clean it, o2 sensor and so on, you will be amazed at how basic it is once you find it. hope that helps if not their are a few other methods that can be done ( usually the problem is staring you right in the face)
Really? The thread is 4 years old! Do you not think he had it fixed by now?
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
