lol, rate it :)
How did the big dive up the inside go @ 35 seconds? It was chopped :D I think I know why......
From memory the GT3 was posting lap times around the 1min 18 mark. Good drive but wouldn't let faster traffic through which was a pain. The first time I went to get passed was the "big drive up the inside @ 35 secs", it wasn't pretty.... :whistling: 2nd attempt to get passed was a lap later also on the entry into a hairpin which went to plan.
Cheers
Slip.
Typical Dak Dak driver..... many of them seem to remove their rear vision mirrors because they think they're the fastest ever. :P
There is no wanker like a Porsche wanker.....trust me I should know :)
Actually Ferrari wankers are kind of the best - red Schuie suits with matching Puma booties and a 10 second off the pace lap time. Thats where its at Maranello style :)
The Porshe guys are (typically) pretty bad, I've got much video footage to prove it :) AND the cracked widscreens!
But yeah, Ferrari guys are the worst! I'm yet to see one driven properly. lol
Thats just a classic. Well they always say if you dont fly off the track at some
stage you are just not trying hard enough. Welcome to the hard club Seb!!!
Good effort. BTW - do we get to see the rest of that footage soon.
As production designer I demand it...............
Congrats on the 13s mate - I knew you had it in you.
I'll look forward to getting out there and rubbing door handles with you soon.
Martin, you must be pleased to see this weapon out there pulling the times.
I will have to join the porsche club - looks like a lot of fun.
Willall racing at the porsche day. 1 2 and 3. Domination. I like that.
Maybe they should call it - Come out and get thrashed by a Nissan GTR day!
hahaha
Did they give you a talking to for passing under brakes Seb? I know that GT3 RS and it's not exactly standard as well!
I wasn't passing, just taking the better line... :whistling: Trailer part II is going up.
http://www.youtube.com/watch?v=tWQIc-i4PXg
Cheers
Slip.
lol, very funny. :)
but if you think we have it bad here with porsche wankers you should try going to a track day in europe or even go to a nurburgring tourist session. nothing like putting around in your rental race car with say 250hp only to have a gaggle of 4 GT3RS's all pass you at once like they are fighting over an F1 grid spot as they blast through the fast uphill section at 280+ only to find you up there arse as soon as the track gets a little sliperry or though anything that requires hitting a few apexes. and the sheer numbers of them! nearly every bloke in germany must have a GT3RS. went to a private track day at Spa F1 circuit in belgium and it was like driving your way through a plauge of porsches. and yes the ferrari guys are worse but thankfully few and far between.
PS, I'm not saying all porsche owners are wankers. just that the wanky ones are wankers. and yes I'm jealous and will happily accept any GT3 RS thrown my way and join those manly bavarians and it up around europe. call me Hans.
    • I don't run the spring but it means you need to set your own belt tension.  I put tensioners on both sides too.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
