You can run injector cleaner thru them but when there cleaned professionally they are ultrasonically cleaned I'm not 100% on the process but you could not do the same job at home you maybe able to get someone ( mobile bloke ) to come out and clean them but still would be fairly pricey I would assume
Edited by BOOZTJUNKEY
On the cheap you could try taking them to someone with a jewelry ultrasonic cleaner, though I'm not sure how effective they would be on injectors. Profesionally done they use a proper ultrasonic cleaning bench designed for injectors and have them flow tested and even balanced if the person is good. As far as bottles of injector cleaner go my experience and people who I've talked to who work in the auto trade say they don't do anything significant for their price (some bottle cleaners arent O2 sensor safe for example).
I think getting injectors done professionally is pretty cheap when you do the labour yourself and R&R them, I vagually remember a mobile guy out in WA that people on here have sent their injectors interstate as even with postage its still cheaper than people in their own state.
I was quoted between $150-200 for a mobile guy to come out and ultrasonically clean my injectors (as long as I pulled the rail out prior)
Maybe another $50-100ish if he had to pull the rail out too.
The only thing I would run through my injectors is fuel doctor it's an independent company dedicated to fuel additives don't no I they are outside of qld but a good mate of mine works there and I have used it my self and was very impressed with it I it's designed to clean injectors and fuel systems as well as removing built up carbon deposits I had a set of platnuims out of my old 32 and they were all caked with carbon so I put them in my car when I ran some doctor thru to see if it actually worked pulled them out a week or so later and they were clean as I was shocked lol and fuel economy was better it's good stuff
My 2 cents anyways
  • Like 1
The other advantage to having them done professionly is to flow test them at the same time to ensure all are withn 3% of each other.
then fit the ones that flow the most (if any) to the leaner cylinders, on an rb26 thats #6 then #5
i assume that the same applies for an rb25? the back 2 cylinders (next to the firewall) are the leanest ?
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
