Hey guys,
So basically bought my first skyline r33 gtst series 1 a month ago and woke up sunday morning to the pictures attatched. What the F*** happened? Obviously there was a fire in the car and i have disconnected the batery and called insurance. But want to know worth salacaging it and repairing or complete write off?
and anyone have any idea how or what happened?
https://www.sau.com.au/forums/topic/353114-r33-electrical-malfunction/
Mate sounds like you've bought a lemon, 3 problems gone wrong with it in 1 month? Good luck ever selling that on SAU...
That looks like a pretty serious problem too...
Edited by Dani Boi
holy crap lol... wouldnt have wanted that to happen while you were cruising down the freeway :P
It's good insurance is doing it for you, should have a nice fresh interior when they are done.
Dash, steering wheel, indicator/wiper stalks, ignition barrel, steering column covers and seat just to spot the obvious.
Then depending on what the repairer says it could be possible new gauge cluster if heat damaged and the wiring, maybe a new loom or alot of soldering..
Wow... I've seen and worked on car fires before, but I've NEVER seen anything like that! No idea how that happened! You're lucky it burnt out instead of burning the whole car down!
Any decent mechanic/panel beater will be able to fix that for you.
If I was the installer at JB's I'd be feeling pretty nervous about now, even if they aren't at fault the insurance company we try their luck at placing blame to offset their cost.
Edited by R33 Impul
without seeing the car its hard to tell but if it was the stereo its wierd that its burned through just the steering column, id be leaning towards immobilizer install unless the guy at JB messed with someone elses wiring @ the steering column.
btw are they even qualified at JB's to do wiring? most are just retards in sales that wouldn't have a clue about auto electrics
also u mentioned the RAC had a look at your car recently - http://www.skylinesaustralia.com/forums/topic/352034-engine-problem-possibly-battery/
some of them are also retarded (not all) did he JUST replace the battery or did he stick his head under the steering column? id be mentioning all this to the insurance company as they could of connected the battery wrong or something
My friend had trouble with his indicator making ticking noises for a few months, then once when we were driving smoke started coming out of the steering column thing from the gap where the indicator goes in (hard to notice the smoke at first). It turned out to do be the indicators fault, whilst it was blinking left and only left. We took it apart and I cleaned all the contacts with contact cleaner and that seemed to fix the problem and the indicator ticking noise.
He had no aftermarket alarm or turbotimer or anything installed on his car either, it was all stock electrics and happened pretty suddenly. Possible could have been the same problem as your car?
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
