  • 3 months later...
I have to update this for Steve, as Im just as excited as he is. Big props to Powertune and everyone else involved, but we were out testing yesterday (His our again today), and what an awesome shakedown. I wont post any times or details, ill let Steve do that, but here is a pic
So after the cage getting painted the engine and gearbox was dropped off for installation in March. Work up until this point was faultless. I was quoted 4 weeks until completion.
April....... Wife cancer
May........Kid sick
June...... Kid not his
July.... Separated from wife
August.... Bikies after him
September... Bikies poured sulphuric acid on his hair and my legs were broken
I genuinely felt sorry for the cnut. I have succumbed to the fact that he is mentally not there. Through my observations and from my opinion (medically based) he is a compulsive liar (only the seperation part is true) which makes it very hard to deal with. Just check out his trader thread. That has only unravelled the tip of the iceberg...believe me! . I'm not here to discredit his business even though he has cost me tens of thousands through missing parts, engine failure due to poor workmanship.
So lets move on to the awesome part ;)
I had to goto the workshop to hijack my own car with a few mates unannounced. As I have a car to prep for wtac ;p
VSPORT next stop... Brakes, suspension, dry sump sorted! Superb efforts there from Todd and Johnny
POWERTUNE to finish the car for testing.... Fcking awesome gig they run there! They do everything!!!
HALTECH - so generous with time and support and such a awesome product when understood
Justin from PROWIRE who wired the whole car up without fault on the first start!!! Drops panties bro lol
Anyway.... Shakedown was frigging awesome. Could not fault the car mechanically. Haltech setup my whole data logging trackside and once again there efforts are above and beyond.
I destroyed my front left canard yesterday collecting a witches hat under lock up but I'm still getting over the novelty of clutchless shifting :P
Boz doing what he does at TRACKSCHOOL tested the car............. Video to come .......
I can't believe it's this quick out of the box so early in its testing without any aero and on its run in tune.... And weighing in at 1420kg :P
Ur "mate" did the dash I think haha
That's right.... ur mate that sent away ur exact brakes lol
just alloy wrapped in carbon.
Shifter is a custom made extension by powertune on a pivot to give the exact same consistent throw to the holinger plus signal to the Motorsport systems strain gauge shifter. It also gives the driver a back and forward feel.... vs the easy dog leg option which gives inconsistent and weird angles of thow. All this because the seat position is at the passengers rear foot rest ;)
Mouth watering for sure!
Big novelty for me at the moment pulling that big knob...all I'm thinking of is getting to sixth and bleeping the throttle on downshifts on the peddle box. Until I'm comfortable with that ill start zoning in on my lap times :P
Car is looking awesome. Can't wait to see some shakedown vids and the car out at WTAC!
Who was this in refernce to?
May........Kid sick
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
