In hindsight, Holinger have supported me every step of the way thus far.
I got a call from AWARD diff and gear as I was co-ordinating flight times and scheduling for the team back
at Powertune to present the car for WTAC...
Terry said that the parts are on there way up.... next flight out of Melbourne and will arrive at his doorstep 11pm
He will then rebuild the box for me overnight and call me as soon as its ready....... YES!!!!!!!!!!!!!!!!!!!!!!
12am... SMS.... flights are delayed because of bush fires....ETA is 1am for delivery....get some sleep was his last words!
Mind you, the average sleep per night from myself and the crew at Powertune was about 3 hours for the 2 weeks leading
up to WTAC... and there was a few nights I was relegated to the couch at home lol Mrs is a champion!
4am.... come pickup the box..... Boys at Powertune had setup the car on a hoist and were on standby to put this box in
as soon as it was ready! 5am box was back at Powetune.... And car was on dyno 7am the morning of Day 1 WTAC
Forgot that amongst this, between wed and thurs I had the car at heasmans for suspension readjustments. Softer springs went
in and car realigned and weighted. VSPORT who originally did this had there own troubles..engine failure on the evo10 and Kallis
evo9 lost its rear hub.
Thanks to Brad at Heasmans for taking the car on with such late notice.
When it was patiently waiting for a box at Powertune the morning after, the guys at Motogrpahics did the decals! Wicked!
  • 1 month later...
  • 8 months later...
  • 1 month later...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
