This build is amazing mate!!! Cant wait to c how u go with the new setup!
Cheers
Herb
Thanks mate !
Waiting on head for install of mew valve train and final assembly :)
Flow bench tested....
Will swirl and tumble like a washing machine :)
Some Tomei goodness
Decided to O-ring block :P
One bottom end ready for punishment ! All clearances checked to spec! Apparently it took about 45mins per cylinder :cheers: Greg !
  • 3 weeks later...
Dummy assemble to check piston to valve clearance :)
It's playschool :)
Valves
Seats cut bronze valve guides knocked in ...
Dual valve springs And oversized valves
Some lab work - cc'ing chamber
Current comp ratio 8.5:1 :P time to grind the head ... Master at work setting up machine
As they say ... A engine builder is only as good as his machinist ... This is a work of Art !
  • 2 months later...
  • 6 months later...
Back to the top for this one,
Its getting a face lift
When someone drops a car like this off at pro fabrication and says I dunno what I want just make it good the wheels start to turn.
Ive designed and FEA tessted the following cage and thats whats going into this R34
Front section to strut towers
His exact words were "your in control" so the car will have some easy weight removed.
The idea so far is to remove the rear fire wall and fabricate up a smaller alloy one
Cut out the interior 3rd skins in the rear quarters.
Drill out the spot welds and remove the 2nd steel skin on the fire wall. (2nd skin on the trans tunnel will remain.
Remove all the brackets and studs etc that are no longer being used.
Seam weld the chassis and also reiforce the chassis rails
Should be interesting
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
