hey Steve,
any issues with temps after the grout fill job?
Yo,
motor just got stripped down and reported on.....
Engine temps and water temps were fantastic whilst on track
max of ~90 degrees after each session (air guides/twin thermos air/breather tank were fabricated)
draw back.... concrete caused a hairline fracture upon setting (still tracked for 6 events after) :)
all parts in great condition, would reuse consumables if a street car but not taking any risks with new N1 block
:cheers:
Fire wall bars are cut that accuratly we can weld the tube back to the fire wall to seal it up, no cut plates required....
And on the inside shit just got wild
Hopefully finish off the front end of the cage tomorrow, few more bars to through to the strut towers and more chassis reinforcement to come.
First stage of this monster cage is now done.
Basicly there are plates welded to the area of the floor where the chassis rails are spot welded to the fire wall. The tubes running to those plates actually go through the plate and are welded to the inside of the actual chassis rail. The plate is then welded ontop to reinforce the rail to both the cage and the fire wall.
There is obviously tirangulation to those critical pick up points.
There is 3 bars running out to 3 points on the strut towers.
One horozontally out which will oppose the side intrusion. One out to the strut top and tower intersection which is X'ed inside the car and another from the base of the front leg to the side of the tower where the camber arms are bolted to.
The bar at the base of the front leg to the chassis rail bars is there for two reasons, one is to aid in a side impact, transfering the force to yet another strong point of the chassis and also to provide a triangulated support for the main rail support bar.
enough explaining, enjoy the first stage of what is probably the most comprehensive cage anyones ever put into a skyline.....
Steve mentioned people were asking him how the car was going.
Update, the cage is nearing completion, hopefully tomorrow the hoop will have its diagonals and the front bases plated up.
Fab work left is some new jacking points under the car, pedal box frame and install, seat mounting and a new steering coloum.
Then a rewire before being sent off for paint
Back to the top for this one,
Its getting a face lift
When someone drops a car like this off at pro fabrication and says I dunno what I want just make it good the wheels start to turn.
Ive designed and FEA tessted the following cage and thats whats going into this R34
Front section to strut towers
When you say 'FEA tested' what exactly have you done. I'm assuming a beam model of the cage minus chassis looking at torsional stiffness? How much optimisation is done (stiffness vs. weight) - I imagine there are diminishing returns when you start adding that much bar work.
Just cage modelling correct. We are mainly looking for ways to even out the load distribution and maximise torsional strength.
Weight vs ridgity is factored,
Obviously as you say there comes a point where the cage just becomes heavier without adding any strength. I questioned the small bars running from the base of the front leg to the chassis rail mounts. When removed we lost side impact resistance on the front leg. 1.1kg worth of bar that was worth while.
There wasn't much else that we tried which added any great benifit.
The only thing I'd like to have changed is the location of the X between strut towers. I think it should have been wider but engine restrictions prevented it.
The engineer we use to do these designs with us here always harps about intersection location. Problem is when you take the design to a car a lot of the time locations can't be exactly where they are desired.
I just seen your PM too ill send you a quote tomorrow.
Went in today for a seat fitting.... I have to say that the quality of the workmanship speaks for itself. To see it come together from scratch is truly amazing.
Motor duties have been appointed to PowerTune for a freshen up... N1 block now replacing the cracked concrete block. They were really impressed with the condition of the bottom end... Credit to the dry sump by PFRE and machine/assembly work carried out by Greg at Duncan and Foster.
The rollcage is now completed and the body has been seam welded. Looks like a mess but once painted will be tidy.
The custom steering coloum is also finished.
We start with a shaped plate on the firewall and mount a spherical bearing and carrier to the plate.
Using 25x2.1mm 4130 tube the steering colum passes through the spherical into the engine bay.
I've machined up a basic 6061 series alluminium block to house the upper roller bearing in and support the end of the shaft.
More bar work from the bearing plate to the cage and bulk head support the coloum.
Modified sparco adaptor is welded into the shift and a roll pin is drilled and banged in for extra security.
This steering coloum is exactly how the V8 Supercar colums are done.
Pedal box mountings are underway but not completed yet, custom throttle pedal is also underway. We couldn't use a 3 pedal box due to the design of the cage. A custom pedal is being fabricated to clear the lower cage bars.
Fabricated pedal box mount completed. Reinforced with 1 inch 4130 tube back to the lower chassis rail support bars.
Decided today that the car is going to need some new jacking points under the car, the chassis rails have been squashed and the sils damaged from jacking the car up all the time at the track. Some specific jacking points coming from the cage will save the cars structure
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
