Hey guys any help would be legend
Iv got a project 32 gtst rb20det which is basicly finished
Took it for a run the other day was running amazing ! no lag somehow (has fmic stock turb) boost was creeping even tho no boost controler(has to be boost leak?)
Then the next day took it out unlimited boost prety much wtf! yes i checked all the lines evrithin seems to be sweet and tight c;lamps on EVRITHIN (thort actuator line came off but didnt)
But the thing is it was gutless on boost? and unlimited over nyt? has waste spark setup also .
How the hell does it go from perfect to unlimited and gutless on boost ? feels like its hesitant
Any opinions ?
https://www.sau.com.au/forums/topic/353141-rb20det-boost-problem/
unlimited boost means there is no pressure signal getting to the wastegate actuator. that means either split hose (can be sometimes hard to see), hose come off (should be easy to see) or the system is not hooked up correctly. you need to take another look at the boost control piping or get someone else who really knows how basic boost control works to check it for you.
Iv got a project 32 gtst rb20det which is basically finished
Took it for a run the other day was running amazing ! no lag somehow (has fmic stock turbo) boost was creeping even tho no boost controler(has to be boost leak?)
Then the next day took it out unlimited boost pretty much wtf! yes i checked all the lines evrithin seems to be sweet and tight c;lamps on EVRITHIN (thort actuator line came off but didnt)
But the thing is it was gutless on boost? and unlimited over night? has waste spark setup also .
Any opinions ?
This sites fkn LEGIT
Cheers guys yeah i think ur right guna check out the hoses for splits its gta be it. the dump pipe isnt split so gates fine (i think lol will check anyway)
f**k i bet itd be real lean lol
Good definition on the unlimited boost ! f**k u both have gtrz!!!!!!! f**k take me for a blat lol
Good Kunts!
