Can't Play Mp3's
g35me
 Share
Can't the '09 model play MP3's or am I just doing it wrong? I just burnt a DVDR with some MP3's on it and wanted to then copy it to the GTR's hardrive and it wouldnt even read the disc. Is it because it is a DVDR or because they are MP3's? Thanks.
yeh you can only rip non-mp3's to the hard-drive, you'll have to make regular discs from your mp3s and then rip them - nero will do the conversion
i have never tried an mp3 disc yet, i always just stream off my iphone
as you know, i now have dvd in motion working - did you check if you can play dvd's?
Edited by domino_z
bummer. even the "old" 08 JDMs play DVDs. They gave a cool DVD with the car and I watched it in the car. lol. and even funnier is I was in the DVD as I was at the GT500 launch way back when and nearly got run over by it. good times!
yeh the JDMs have the full audio/vid package
for the Aus spec, they dumbed it down with the analog system, even reducing the screen resolution, so all 09's were unlucky there
for 2010 build onwards, they got the newer digital system with improved screen res
im sure our resident tech guru will correct me here if im wrong
Mp3's will work with CDR's (not DVD) on the 09. As mentioned above I don't think/know that you can rip those to hdd though.
 Share
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
