yeh you can only rip non-mp3's to the hard-drive, you'll have to make regular discs from your mp3s and then rip them - nero will do the conversion
i have never tried an mp3 disc yet, i always just stream off my iphone
as you know, i now have dvd in motion working - did you check if you can play dvd's?
Edited by domino_z
https://www.sau.com.au/forums/topic/353224-cant-play-mp3s/#findComment-5663991
bummer. even the "old" 08 JDMs play DVDs. They gave a cool DVD with the car and I watched it in the car. lol. and even funnier is I was in the DVD as I was at the GT500 launch way back when and nearly got run over by it. good times!
https://www.sau.com.au/forums/topic/353224-cant-play-mp3s/#findComment-5671142
yeh the JDMs have the full audio/vid package
for the Aus spec, they dumbed it down with the analog system, even reducing the screen resolution, so all 09's were unlucky there
for 2010 build onwards, they got the newer digital system with improved screen res
im sure our resident tech guru will correct me here if im wrong
https://www.sau.com.au/forums/topic/353224-cant-play-mp3s/#findComment-5671249
Can't the '09 model play MP3's or am I just doing it wrong? I just burnt a DVDR with some MP3's on it and wanted to then copy it to the GTR's hardrive and it wouldnt even read the disc. Is it because it is a DVDR or because they are MP3's? Thanks.
Mp3's will work with CDR's (not DVD) on the 09. As mentioned above I don't think/know that you can rip those to hdd though.
https://www.sau.com.au/forums/topic/353224-cant-play-mp3s/#findComment-5685068
