Dear Skyliners,
Can anyone help me identify this container and its purpose? It is located beside the throttle body/intake manifold. It has a "Max"and "Min" level indicator as well.
It contains some black liquid which is very close to the "Min" level. Do I need to top this up? If yes, with what?
Many thanks.
https://www.sau.com.au/forums/topic/35323-identify-this-r32-gtst-container/
Thanks mate.
But is this the only cylinder that I have got to top it up with brake fluid?
Where is the other one? I understand that I need to top up the "brake cylinder" as well.
Or are both of them combined into this one container?
Dear me, the things we have to put up with.
It's the clutch master cylinder! It probably needs some fluid; brake fluid.
I've always wondered WHY people would want to 'TOP UP' their brake fluid inbetween brake pad changes, it gives you a good idea how much brake pad you have left.
When the brake pads wear the brake fluid level drops as the calliper pistons are sitting out more. Hence leave it unless it is below the low level.
I doubt the wheel cyclinders are leaking however it is possible for the brake master cyclinder to leak, they generally crap them selves.
If it is leaking you will see a line of fluid coming from below the master cyclinder, either in the engine bay or inside the drivers foot well roughly where the brake pedal is.
My Clutch master cyclinder crapped its self soon after I fitted a new heavier clutch. It was leaking fluid inside the car (down the clutch pedal causing my foot to slip). It set me back $70 for a newy from a local brake and clutch specialist. The clutch master cyclinder shouldn't require topping up ever.
Every brake pad change flush out the old fluid (both brake & clutch) and in with the new.
There is a junction box that also requires bleeding for the clutch on the R32's.
My Clutch/brake fluid always appears to get a little dirty. I am unsure why I am assuming the previous owner(s) hadn't changed fluid within the cars 10yrs life. When changing fluid I notice a noticible difference in brake response. Its soooo much easier to lock the brakes.
Go grab your self a few bottles of brake fluid, by the colour of that fluid it looks like you will be needing it. :D
    • We are literally just kids stuck in an adult's body with bills and mortgages to pay 🥲
    • Behrman is great quality stuff. My 34 has some serious clouding as well but I’m too nervous to try and replace the glass myself so I haven’t bought them yet.
    • This might be true if you live in NZ but I can't see how this could be true for us locals here.  I've found the customer support for Haltech to be absolutely amazing. I've turned up to Haltech and spent entire days with their tech support guys, they've even helped me with wiring dramas that had nothing to do with their products.  They have the best customer support of any company I've dealt with, I can't imagine how my experiences with them could possibly be any better.
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
