Dear Skyliners,
Can anyone help me identify this container and its purpose? It is located beside the throttle body/intake manifold. It has a "Max"and "Min" level indicator as well.
It contains some black liquid which is very close to the "Min" level. Do I need to top this up? If yes, with what?
Many thanks.
https://www.sau.com.au/forums/topic/35323-identify-this-r32-gtst-container/
Thanks mate.
But is this the only cylinder that I have got to top it up with brake fluid?
Where is the other one? I understand that I need to top up the "brake cylinder" as well.
Or are both of them combined into this one container?
Dear me, the things we have to put up with.
It's the clutch master cylinder! It probably needs some fluid; brake fluid.
I've always wondered WHY people would want to 'TOP UP' their brake fluid inbetween brake pad changes, it gives you a good idea how much brake pad you have left.
When the brake pads wear the brake fluid level drops as the calliper pistons are sitting out more. Hence leave it unless it is below the low level.
I doubt the wheel cyclinders are leaking however it is possible for the brake master cyclinder to leak, they generally crap them selves.
If it is leaking you will see a line of fluid coming from below the master cyclinder, either in the engine bay or inside the drivers foot well roughly where the brake pedal is.
My Clutch master cyclinder crapped its self soon after I fitted a new heavier clutch. It was leaking fluid inside the car (down the clutch pedal causing my foot to slip). It set me back $70 for a newy from a local brake and clutch specialist. The clutch master cyclinder shouldn't require topping up ever.
Every brake pad change flush out the old fluid (both brake & clutch) and in with the new.
There is a junction box that also requires bleeding for the clutch on the R32's.
My Clutch/brake fluid always appears to get a little dirty. I am unsure why I am assuming the previous owner(s) hadn't changed fluid within the cars 10yrs life. When changing fluid I notice a noticible difference in brake response. Its soooo much easier to lock the brakes.
Go grab your self a few bottles of brake fluid, by the colour of that fluid it looks like you will be needing it. :D
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
