Hey guys, ok so i bought an R31 with decent power, box is screwed but ive just bought a new one and the clutch is slipping so im thinking ill change that at the same time. what clutch should i get?
I need one to handle 300rwkw or close to just wanted to know my options. thanks guys!
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/
I have searched and it seems jim berry is the best for track and there isnt much more about clutch options, im asking what people have used that works well on the street because im not going to be putting 300kw thru it for long periods of time ( only now and then ) and im not planning on dumping the clutch at 7000rpm, i just want to know if someone is in the same position as me and what they have used that worked
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5660880
jims a great guy to deal with, but hes sooo over priced
i got a modded exedy 5 puk from a guy in sydney (Parramatta?) 4000ish pound clamp load with carbonic pads/puks.
Jim quoted around $7-900, the other guy (who i would of sworn was jims long lost brother, really nice) was $360 including shipping to act.
so far good for 285kw and 700ish nm's
if you want ill track down where/who it is.
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5661846
wow ok, i really dont have 2200 to spend on a clutch right now as im still spending money ironing the bugs out of this engine, ( one day ill put it in a 32 with a 25 head ), i got lucky and picked this car up with a fully forged and balanced bottom end for 3k. i use this car as a daily for now and sounds like the guy from sydney is my best option. when i get abit more serious with it and track it ill go for the better clutch. could you pm me the number so i can call and get one sent to me? cheers :thumbsup:
Edited by mungy
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5661921
i run an exedy HHHDBC with 325rwkw
not the best for a daily, but grips up hard and fast on track, i'm absolutely in love with it. well under a grand.
jim berry's are nice... but my legs are nicer ;)
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5662364
for anyone else interested -
K B Clutch Engineering
143 Coreen Ave, Penrith, NSW 2750
Outer West Sydney, Western Sydney
p: 02 47321692
Speak to Keith, he's the man. really top guy to deal with.
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5667271
I've just heard more bad things then good things lately about Jim berry clutches. There's a thread from not long ago where one of his clutches welded itself to the flywheel. Apparently it's not the first time this has happened
Nismo twin plates are great, but if it's out of your price range I highly recoend NPC. After having an NPC I wouldnt recommend anything else. It grips hard and is quite soft for what it is. They are quite reasonably priced to
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5669329
hey where do you get the TRIPLE HDB, i have talked to atap ( clutch supplier for my work ) and then exedy all they have is "NSK 7056HDB" which is rated to 330rwkw and is bout $600 without trade discount. is that the one your talking bout.
the description is on their website and. i am just interested as i am going to buy one but says nothing bout HHHDBC
Size, Spline OD & No. of Teeth
240 x 25.5 x 24
Flywheel Profile
Flat
Additional parts - not included in kit
Alignment Tool
DCT-01
Spigot Bearing
PB-22
The Heavy Duty Button (HDB suffix) clutch kits are manufactured to meet the demands of various forms of amateur drift, circuit, rally and drag racing and are assembled from 100% new component parts. All HDB kits are supplied with high clamp load clutch cover assemblies and ceramic button clutch discs with sprung dampers.
Edited by PaulosECR33
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5684232
NPC FTW..they build to your desired specs and ships straight to your door (or the mechanic in my case)
super easy to drive and bites hard every time. when it burns out, you can send it back to them to get rebuilt with new clutch plate etc
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5684984
