Hi Everyone!
Car: MQ Patrol – the bush basher / daily driver!
Deck: Pioneer, with front pre-out and rear/sub pre-out.
Amp: Sony XM-460GTX, front channels to splits, rear channel bridged for sub.
Speakers: Splits and sub.
Problem:
Installed this about 12 months ago – working fine. Then the sub started to quieten, adjusted deck and amp, all good for a while, then one day the sub cut out completely. Checked wiring etc. all good. Played around with RCAs, when I unplugged one rear channel RCA, sub got loud, as I was plugging it back in front speakers crackled and sub cut in and out. I left only one rear channel RCA plugged in as a quick fix – all good. Sub died again. Completely unplugged rear (sub) RCAs – sub loud again. Left as is. Driving along one day – normal road, sound cuts out. Next morning back on, then when driving to work, crackles and cuts out – all speakers (sub and splits). Think it is possibly the deck, take home CD player with RCAs outside, power-up and plug into amp through RCAs – no sound on any channel – can’t be deck – must be amp. Play around with RCAs – no good, no sound at all – all fuses good, power and protection light still green. Take amp into A1 Audio (Perth), who test on bench for a week in different modes – no issue. Take hone last night and put back into car, working fine, and then sub cuts out again. Unplug one rear RCA and sub back and loud again, unplug both rear RCAs and sub as loud as it should be, front speakers working, but no sub control through deck as no rear RCAs plugged in.
Sorry for the long description, but does anyone have an idea what the problem would be? The guy at A1 said the RCA inputs on the amps sometimes pack up, but when they tested everything it was fine?
Any help would be much appreciated, as I just want to have the amp running normally, and be able to control the sub from the deck as it should be.
Thanks!
Peter
https://www.sau.com.au/forums/topic/353250-intermittent-sound-from-amp/
have you run another RCA OUTSIDE the car to the amp or swapped the front and rear RCA around for testing ? you could have a bad solder joint on the RCA wires or pinched wires under a seat or bolt
your sure they checked to make sure the amps RCA jacks aren't broken off the curcuit board, very common lately on made in china gear. without solid support, and in a truck break even faster from vibrations. easy to fix if so.
give your wires a wiggle test while on low volume , starting with the amp area, then under the dash. ???
if the deck/truck was offroaded severely then maybe, depending on if it has rotary controls or push button ? what model pioneer radio? removable face ???
Edited by sapphiregraphics
Thanks for the reply!
- When the amp stopped producing sound completely, I took my stand alone CD player from my system in the house, ran an extension cord out to the car, and plugged the RCA jack of that into the fron and back channels, adjusted the gains and still no sound? So I thought definately not the RCAs outputs from the deck.
I'll switch the RCAs around from the deck again today, and see what happens. I took apart the amp and it seems that the RCAs aren't broken - and A1 Audio checked this, and like I said when they tested it on the bench everything was fine!? But as soon as it goes into my car the rear sub channel starts playing up, and the front speakers crackle and cut in and out as I move the rear (sub) RCAs on and off the terminals?
I'll try the wire wiggle as well...
The car is not off-roaded that severely, I always take it easy - the deck is detachable face, with the buttons all flush, and a little rotary controller in the middle - I can get you the model if it makes that much of a difference?
Any other suggestions?
Thanks!
Peter
Troy
another possibility (it's a bit out there),
could the voice coil be rubbing on the housing (Distorted basket from the bushbash'n), creating a partial short ( reduced volume) and overloading the amp (total sound loss)
Peter
Try bushing the sub cone in gently (spreat ya finger tips around the centre of the sub) does it float gently, or can you feel a scratchy sensastion
yeah could be a dragging slightly burnt voice coil , or a tensil lead from the voice coil to the solder joint on the speaker frame shorting out on the speaker frame when it moves just right or plug inside the speaker box
is loose ???.
a few of the older sony stuff had bad capacitors on the pre amp side of the board, but most of the time they would go into protection or squeal loud internally to the amp itself.
sorry I missed the testing of the deck already, rotary dials and detachable face decks get dirt in the connections and do weird things. drop out etc. dirt roads and car audio dont mix well...lol
use marine equipment if you drive in the dust all day long.lol
along the same vein as above/those in the know + my 2 cents.
if system as been in for a while, perhaps check over, trim ends of wires/terminals and re-terminate terminals to speakers/amplifier.
make sure all nice tight/good contacts. Hopefully no loose terminals on the amp to circuit board or speaker basket to cone themselves.
whilst everything good on a new install, good to check over every 2yrs with vibrations/knocks/pot holes etc..
(which re-mind's me, getting a bit of hum, gotta check the earth on rear amp)
    • Hey all, It's been a bit since I have been able to update.  I pulled the fuel pump, first off it was a "universal" pump and the strainer was very clogged, and it was folded over on itself.  I replaced the fuel pump and all is well....  No more stalling.
    • That's convinced me I'll bump up the G30-660 to 770   Any idea if the difference in boost pressure? Cheers
    • When: Saturday 24th of May 2025 - All day Where: Sydney Dragway, Eastern Creek Cost: Varies - Book direct with the GTR Festival Website We will be there on the day with a stand please reach out via our interest form if you wish to help out with the stand. Limited parking will be available in the display area, first in first served with current members getting priority, please register your interest with the link above also. Please post any great photos you take on the day on this thread and we will try use some in our e-mails/website/social media
    • Hey guys so turns out this project is going to be much bigger than I thought haha but I've done some my homework and have done a few panels on my car, but one part I can just not visualise is this. If I do a spot repair and I put filler in a dent for example and sand outside of the repair with 320 grit lets say so the primer can stick as I will only put primer on that repair and the surrounding area and then repaint the whole panel. Don't I need to make sure that I don't put primer on the old clear coat? I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down, it's still shiny. I thought putting paint on clearcoat or primer on clearcoat is a bad idea because it won't stick. So in this scenario it's a bit different to mine but imagine someone doing a spot repair and only painting that small section of repair but the new paint is landing on the old clearcoat. What am I missing?
    • I was immediately reminded that your location is QLD. Sounds like a perfect SEQ business idea.
