I found the hardest to get used to until your out there... is the double apex on turn 2... so much tighter then you expect hence why I went off onto clems precious lawn lol
do you mean turn 3? after the pits, its a pro corner when u do it right but tbh i think its one of the hardest for a new driver, takes a few turns befor u learn where u should enter
having a good handbrake is huge, sucks so much going into a corner and pulling the handbrake then nothing happens, cant wait till i put R33 rear brakes on my 180sx
  • Like 1
And As Import S13 said be careful of the turn 1 inside ripple strip.
I bent a strut hitting it, several other cars have done suspension damage hitting it.
Evan Daws rolled his R31 a couple of years back hitting it.
Yeah its nasty
I snapped clean the linkage to the sway bar making my whole wheel swinging freely and in doing so bent my strut, bend a rare 16" long champ rim and smashed my guard in while also made the car VERY hard to get on the trailer haha.
You would think Clem would do something about it insted of spending the money on more tyer walls!
Nah I reckon He meant turn 2, turn two really is a double apex corner, It tightens on the exit, so it is really easy to start to run wide early.
Turn 3 the way I like to do it is be going in real fast the down shift hard under brakes 4-3 then mild scando while still braking while shifting 3-2nd put it in with big angle and the just about rub the nose of the car on the apex tire stacks near parallel to them.
Gives an extremely slow exit speed but dam its fun and its a non judged area any way
yea it tighttens but there is only one apex, you pretty much start wide, cut into the corner and ride the ripple strip for a bit then push the car towards the exit of the corner
with turn 3 it looks like you should cut into the corner befor u really should, u have to go a lot wider then it looks to hit the apex and stop yourself from being pushed off the side of the track, its all about learning when to enter and knowing when to cut into the apex imo
yeah murph knows what I mean... I guess it may not be a double apex but feels like it lol. Explain it well, start wide and ride the ripple pad all the way around, so much fun.. Just hard to get it nice and wide while in the transition from turn 1. Pwoah all this drift chat is making me eager as f**king to get out there!... I'll have my video camera getting track side this weekend so hopefully some of the boys get some decent entries and I'll get some good footage :)
I've got R33 rear brakes with hydro so my h/brake setup is pretty sweet. I just need more power which I am working on atm.
Weez, found out that the brand new 040 we dropped in my car was f**ked. I blew that 10 and then 20 fuse now got a 30 init.
SKR said they just upgraded my pump from a 040 haha will be out on the track sooner rather then later now. Just need to upgrade turbo, tune and smash some panels!
What a pain in the flamin mongrel that is!!
Sounds good man, you know what turbo you going for?
I get my 2871R dropped off tomorrow :D
After craigus busting chops looks like next time I'll be out will be stadium drift round 1 - Never skidded at tailem before but eh I don't care, and theres a street class I'll slot nicely into haha... Basically only going for the passanger runs :devil:
Grant: sweet good to see you're gonna slide it... it will serve you well! handbrake should be ok.. was working the last time i saw the track but a good tip is to make sure you use a bit of weight transfer while pulling the handbrake.. if you HB in a straight line it will be a lot harder to lock the rears.. plus its gay that way anyway.
Tailem bend is having a prac day on march the 12th which is open to anyone. you'll only need one pair of brand new tyrs and they will last you the whole day and then some to drive home on. from there you'll need fuel, entry fee and so on... theres no reason you couldnt do your first day on a budget of 300-400
hmmmmm, ill see what money i can scrape together. may not be able to swing it by then though. Going away to Melbourne on the 28th march for work and i want plenty of money to spend there :P
i think i'd rather go to tailem though, considering like you said "theres less shit to hit". So that will be the go for me. also trying to get a mate to come to the drift school with me for a practice.
hopefully i will see you all out there by mid this year!
OH! and where do i sign up for drift school aswell?
Edited by Stagea_G
keep an eye out on the mallala website they will have dates and forms once they have sorted it out.. they usually have 2 a year... its well worth it if your a beginner and want to learn the basics... but anything more then that i'd recommend just keep hitting the track... practice practise practise is the key
yea i will sign up as soon as the forms are available, by may i should have the funds to give it a go.
and im pretty sure the 32 will do it no problems ;)
i saw an old vid of yours, did it use to have a vertex style kit on it?
Edited by Stagea_G
wwwaaahhhh?????
lol, a brand new set of neutons lasted me feck all there! given it was a hot day i spose they didnt do too bad, but defs take more than one pair...
and yea weez, stadium drift Rnd 1 in may, we WILL be there.
:cheers:
What sort of scruitineering is involved for the drift school days?
like standard sorta thing? or is it like a practice where you just sing a piece of paper saying ya cars all good?
Edited by Stagea_G
its common sense stuff... working lights.. secured battery.. etc
craig i ran a pair of federal 595's and they lasted all day with many thrash laps and thats with 350 + rwkw lol... step away from the neutons man they are no good once you start pushing hard.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
