It'll be the light switch itself. Ive just repaired my switch as I was having exactly the same problem! No dash or parkers but had headlights and brake lights...
The little plastic spring loaded triggers in the switch that move the metal contacts wear down giving you the problem youre have right now.
You need to disassemble the switch and replace the worn spring loaded trigger so it once again contacts the metal switch.
Think of the bushes in an alternator, same concept.
There is a thread with pics if you do a Google search, think its on another Skyline forum.
Edit - Here you go http://www.skylinesaustralia.com/forums/topic/115618-r32-headlight-switch-and-dash-globe-replacement/page__hl__r32+switch
Edited by NSNPWR
  • 6 months later...
Edit - Here you go http://www.skylinesa..._hl__r32+switch
I have this exact problem right now in my 1994 R32 GTR , any chance of what its worth for a new switch ? thanks !
Edited by sultanaz
K so I've received PMs regarding this...
Use the guide in the above link
And I paid $50 for another 2nd hand working switch cause I needed it at short notice..
*pic not my car, random off google
Edited by 10 4
  • 1 month later...
It was the switch that was causing the problem, the switchs themselves are heaps shit, worst quality to be honest... it burnt my wiring too which was expected, so what i did was went to the wreckers and pulled wiring off a N14 pulsar which connected straight up. obviously had different colours but u do the obvious and take notice what wire goes where before u cut the burnt harness.
Heres a few pictures of the switch for anyone for the future.
Heres the burnt Wiring and Switch photos
And a Computerised Version listing of R32 Parts.
Hope that helps. Got any questions then give a buzz.
Edited by sultanaz
  • 8 years later...
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
