  • 3 weeks later...
I think Rezz can get them?
i too am looking at the ganador mirrors for a R32 GTR...i found 2 places that sell them
takakaira - normal ones unpainted 35000 yen about $436 plus tax which = ??
2. carbon ones 57000 yen $710 plus tax freight...?
from http://www.perfectrun.com.au/real_size_ima...raeromirror.htm
with 15 per cent discount.... normal $ 505 plus freight
carbon $710 plus freight...
Either way they seem abit much ... cany anyone get them for a better price?
Also i have a friend going to japan around june-july'ish can these be found in your local autobrac's and will they be cheaper?
any thoughts appreciated
https://www.sau.com.au/forums/topic/35337-ganador-mirrors/#findComment-731404
I only get the East Bear or Nick's ones... they're smaller than Ganadors, but more expensive.
would you be interested in sourcing a set and sending them down..?
for a R32 GTR...DaiOni said the normal ones are around 30000 yen...How much would they be sent to melbourne? if your interested in chasing it up...
R32 GTR ganador aero mirrors....
cheers
https://www.sau.com.au/forums/topic/35337-ganador-mirrors/#findComment-732384
I would like to let people know that Ganador dont actually make GENUINE CF mirrors :D
I bought a set of these for my old 33LM GTR and paid extra for the carbon version , so imagine how pissed off I was when they came and they were just a horrible pattern thats supposed to look like carbon :goddam: :goddam: :goddam:
I just think people should be aware of this fact as you pay extra for CF and it isnt really CF your getting
https://www.sau.com.au/forums/topic/35337-ganador-mirrors/#findComment-732756
can the Ganador mirrors fold electronically ?
Each product comes with the same wiring plug as genuine one, which allows you to plug it straight into original factory wiring. The angle of the mirror glass can be adjusted by using original factory switch. (Except for mirror folding function)
*Mirror body can be folded manually
taken from the site i linked...abit of a shame ..but atleast you can fold them manually i suppose....
https://www.sau.com.au/forums/topic/35337-ganador-mirrors/#findComment-733195
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
